Old 09-23-2009, 07:52 AM
omidbrb omidbrb is offline
Calling vizard functions in a loop
I noticed that if I call Vizard functions that have a visual effect in a loop, the commands wouldn't be run before the encapsulating function returns (even with delays in between) :
def callVizFunctionsInALoop():
	for i in range(0, 10):
		moveAvatar(i)
		takeSnapshot()
		#viz.waittime(someDelay)  #Won't help
		#time.sleep(someDelay)    #Won't help
Here, the snapshots will be taken as if the moveAvatar() function hasn't been run.
Is there any Vizard command that will get around this problem?
Omid
Old 09-23-2009, 10:19 AM
You should be using the viztask module. There are many examples of it in the docs and on the forum.
import viztask
		moveAvatar(i)
		takeSnapshot()
		yield viztask.waitTime(someDelay) #Pause function for some time
viztask.schedule( callVizFunctionsInALoop() )
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 04:14 PM
Vizard won't run wouters Vizard 5 02-05-2008 12:12 PM
