Old 08-31-2009, 03:55 PM
whj whj is offline
Real-time export data to simulink
I'm seeking a solution to output position and orientation data to another computer running Simulink in real time. Does anybody have any experience?
Thanks!
Old 09-03-2009, 05:48 PM
Can Simulink read data coming over a network socket? If so, you can use the Python socket module to send data over the network.
Old 09-04-2009, 10:32 AM
whj whj is offline
I found a UDP Receive block in Simulink. It requires the other end of the communication, which is vizard, to specify the port that receives data. I'm not sure how to do it. I think my code only specifies the port that sends data. Am I missing something?
import socket
COMPUTER_IP_ADDRESS = socket.gethostbyname('192.59.88.91')
PORT = 25000 #The port to send data on
OutSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
OutSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
def SendData(data):
	OutSocket.sendto(data,(COMPUTER_IP_ADDRESS,PORT))
vizact.onkeydown(' ',SendData,'hello there')
Thanks!
Old 09-04-2009, 05:29 PM
This post shows how to send and receive data on UDP sockets using different ports.
Old 09-05-2009, 09:49 PM
whj whj is offline
I'm confused, in the sample code, there is only one port 4999, which is "#The port to send/receive data on". Why does it show using different ports? Thanks.
Old 09-08-2009, 01:51 PM
whj whj is offline
So far I'm sure simulink on computer B can receive data from specified IP address and port over UDP. Then my question is, how do I specify the port that the remote computer B accepts data from in vizard on this computer A? Thanks.
real time collision on animation path whj Vizard 10 10-06-2008 05:38 PM
Real Time Audio Data lomendil Vizard 2 06-02-2008 09:18 PM
Can I get real time Intersense tracking data from another computer on the network? GoldenSun Vizard 4 04-30-2008 08:42 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 12:40 PM
timer question Elittdogg Vizard 5 10-10-2007 03:49 PM
