Old 08-16-2009, 06:07 PM
omidbrb omidbrb is offline
Identifying different nodes
I´m using the screenToWorld and intersectLine functions to identify the object being seen at a specific point on the screen, like this:
http://www.worldviz.com/vizhelp/comm...ersectLine.htm
My question is, is it possible to distinguish between different polygons/subobjects in a 3D model? For example, different leaves of a tree model?
Omid
Old 08-19-2009, 12:38 PM
The link you provided is for finding intersections with physics shapes, from your question though it sounds like you just want to see which sub-object was picked.
You can use viz.pick() to do that. This code uses the gallery model and prints out the name of the child object that is clicked on. If you right cick on gallery.ive in Vizard's resource window you can look through the hierarchy and see the matching names.
The name returned is for lowest object in the scene graph that was picked. If this sub-object does not have a name then the first named object above it will be returned.
#use keyboard navigation, mouse for picking
import vizcam
viz.cam.setHandler(vizcam.KeyboardCamera())
viz.add('gallery.ive')
def showPicked():
	#use viz.pick with mode = 1.  This will return a Vizintersect
	#object which we can use to retrieve the object' name
	object = viz.pick(1)
	if object.valid:
		print 'object name:  ', object.name
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, showPicked)
Old 08-25-2009, 03:58 PM
Hi Jeff,
Thanks a lot for the reply. Pick works exactly as I expected. Unfortunately it doesn't return an id for unnamed objects.
Apart from that, I want to have a function similar to pick, but with arbitrary point in the screen (not bound to the mouse pointer). I wrote the following code, but it's far slower than the pick function. It takes about 5 seconds on each call, but the pick functions looks to be very fast. My question is, how can I implemnet "pick" function with arbitrary coordinate on the 2D screen to be as fast as pick?
def fireLineAtPointAndReturnIntersectingPoint(normX, normY):
    line = viz.screentoworld([normX, normY])
    dir = viz.Vector(line.dir)
    dir.setLength(200)
    begin = line.begin
    end = line.begin + dir
    info = viz.phys.intersectLine(begin,end)
    return info.point
By the way, I appreciate your instant replies in the forum.
Best,
Omid
Old 08-28-2009, 02:54 PM
Have a look at the documentation for the <window>.pick command. You can specify an optional pos parameter that says where on the screen to perform the pick. If you don't specify a position, then it defaults to using the current mouse position.
Internal nodes of loaded model files? dtidrow Vizard 2 05-12-2009 08:55 AM
Creating occluder nodes in .ive file dtidrow Vizard 1 12-09-2008 10:40 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 04:27 PM
Pickling Nodes Vygreif Vizard 3 02-23-2006 10:03 AM
