Old 07-12-2009, 07:22 AM
lilio lilio is offline
Question Call objects created within definitions
I want to create buttons within a definition. Something like that:
def createButton(self, position, pictureOff, pictureOn, name, szene):
		self.Position = position
		self.PictureOff = pictureOff
		self.PictureOn = pictureOn
		self.Name = name
		self.Szene = szene
		name = viz.add(viz.BUTTON, scene=szene)
		name.translate(position[0],position[1])
		name.uppicture(pictureOff)
		name.downpicture(pictureOn)
		name.setScale(12,3.6)
And afterthat I call the def like this way:
createButton([0.25,0.8],'button01Off.jpg', 'button01On.jpg', 'button1', 2)
So I want to set the button-name manually. This works fine.
But now I want to define onbuttondown events, but this does not work!
If I write:
def onButton(obj,state):
 if obj == viz.VizButtonLabel(5):
   viz.scene( 2 )
then it works. But this isn't a very good solution. Because if I create more and more objects, I had to change the number of the buttonlabel.
So I want to write:
 if obj == button1:
   viz.scene( 2 )
But this does not work! I get the error message: global name 'button1' is not defined.
I don't know how to solve this problem.
I only want to create a lot of buttons and want to set the name of the button over a parameter. And afterthat I want to check the onbuttondown event via the buttonname.
Thanks for all your answers...
Old 07-13-2009, 10:52 AM
Your createButton function should return the button object and you should save the object in a global variable with the name you want. For example:
	self.Name = name
	self.Szene = szene
	return name
button1 = createButton([0.25,0.8],'button01Off.jpg', 'button01On.jpg', 'button1', 2)
Old 07-13-2009, 11:00 AM
thanks for your answer. But this does not work.
For example:
I've got this class:
class Button(object):
	def createButton(self, position, name):
		name = viz.add(viz.BUTTON)
		name.translate(position[0], position[1])
		return name
and this start.py
import button
button = button.Button()
button.createButton([0.2,0.5], 'testbutton')
	if obj == button.testbutton:
		print 'test'
viz.callback(viz.BUTTON_EVENT,onButton)
So I want to create a button with the name testbutton. And afterthat I want to check if the testbutton is clicked.
In my example, the button got the name 'testbutton'.
But then, I've got the error message: 'Button' object has no attribute 'testbutton'
What is wrong??
Old 07-13-2009, 11:26 AM
You need to assign the return value of the createButton function to a variable:
import button
btn = button.Button()
testbutton = btn.createButton([0.2,0.5], 'testbutton')
	if obj == testbutton:
		print 'test'
Old 07-13-2009, 12:13 PM
Yes it works!
Thank you very much....
multiple objects durf Vizard 1 04-10-2009 02:42 PM
simply overlapping objects chris Vizard 3 04-28-2008 01:39 PM
putting objects on the screen jargon Vizard 7 05-24-2005 12:31 PM
