Old 06-12-2009, 11:18 AM
Jerry Jerry is offline
Fog on the horizon
I'm trying to make the horizon foggy so that it doesn't look like
a sharp line between ground and sky. The problem is that the
fog works on the ground but not on the sky. Here is my code:
from viz import *
go()
env = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
sky = viz.add('skydome.dlc')
sky.texture(env)
terrain = viz.add('InfiniteTerrain.dlc',1,'456',0,700,15000,0.005)
grass = viz.add('gb_noise.jpg')
grass.wrap(viz.WRAP_S,viz.REPEAT)
grass.wrap(viz.WRAP_T,viz.REPEAT)
terrain.texture(grass)
terrain.emissive(1,1,1)
terrain.command(1,'',0,0)
clip(0.5, 100)
fog(2,20)
fogcolor(WHITE)
Is there a way to make the sky foggy as well as the ground?
