Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 05-08-2009, 09:01 AM
PHart PHart is offline
Simple Head Tracker
Hey Folks,
my plan is as follows:
2 trackers should be enough for a simple head tracking (pitch, yaw).
One tracker (standpoint) is fixed over my head (or between my eyes), the other tracker (viewpoint) points at the direction I look at.
I linked the standpoint tracker with viz.MainView which works fine. But now I need to use the coordinates of my viewpoint tracker to define where I look at.
Sadly it didn't work with lookat( viewpoint.getData() ) or extracting viewpoints coordinates with viewpoint.getData() and using them as lookat x, y and z.
Do you guys have an ideas, experiences with that?
Thanks a lot!
Old 05-10-2009, 06:35 PM
Instead of using the link you could use a timer and then set the orientation of the viewpoint with your yaw and pitch values from the two trackers.
def updateView():
	#Get your yaw and pitch values
	viz.MainView.setEuler([yaw, pitch, roll])
vizact.ontimer(0, updateView)
What are you using for trackers?
CAVE PPT Tracker Help with Orientation Inversion on Up and Down shivanangel Vizard 3 03-11-2009 10:14 PM
Problems with getting head bone rotation right Enlil Vizard 2 02-13-2009 11:24 AM
Awkward neck/shoulder connection when adding custom head to vcc model. vEsotu Vizard 5 10-09-2008 06:07 PM
Interface with Tobii Eye Tracker Uttama_vizard Precision Position Tracker (PPT) 1 12-12-2007 12:31 PM
How to simply texture an avatar's head with a jpeg graphic? vr_boyko Vizard 3 10-26-2004 11:44 AM
