Old 03-27-2009, 10:48 AM
Uttama_vizard Uttama_vizard is offline
Handling of .jpg files
I am facing a typical problem in texturing using .jpg files.
As an example, I am first calling an area and then trying to add a texture so as to simulate a different situation.
import vizinfo #For info box
import viztask #For wait time
import vizmat #Matrix in v2.0
import math
room = viz.add('panorama.ive')
#Add a texture.
sky = viz.addTexture( 'hall1.jpg' )
#Apply the texture to the object.
room.texture( sky )
Now, I am copying the picture and pasting it to paintbrush, where I am changing the pixel dimensions of the picture and saving it as a hall1.jpg file.
Then, when I am executing my vizard file, it seems to me that the picture is coming as pasted blocks (no matter how much I increase the pixel dimensions of my picture in paintbrush) and the edges formed by pasting of the blocks is making the picture look inappropriate.
If someone can suggest me a way of overcoming this problem, it would be really great.
Uttama
Old 03-31-2009, 11:17 AM
Can you post the .jpg you are using?
Old 04-01-2009, 10:22 PM
Yeah, pictures and screenshots would help us diagnose whats wrong.
Just a guess, but it sounds like panorama.ive has some interesting texture coordinates. What does your .jpg look like when you put it on a boring old tex quad? If you are not familar with texture coordinates, check out the "Tutorial: Applying Textures."
Paul Elliott
WorldViz LLC
Old 04-03-2009, 12:29 PM
Surely. Yes, I am using panorama.ive. Then, I downloaded a hall.jpg and trying to add as a texture to it.
I am using the following code:
import math
#Add an object.
#Add a texture.
sky = viz.addTexture( 'hall.jpg' )
room.texture( sky )
On running these lines of code, what I am getting is that there are as if two halls (seems like the picture has been split). I tried to edit its pixels in paintbrush, but, it does not work out.
I am enclosing the hall.jpg file.
Thanks for your time.
Uttama
Old 04-06-2009, 05:20 PM
I don't quite understand what you are trying to accomplish. Do you want this one image to wrap around the whole model or are you trying to eliminate the seams?
Old 04-07-2009, 02:06 PM
I am trying to wrap the jpeg onto the panorama.ive and at the same time remove the seams.
In fact, what I want is, to obtain a different social scenario. But, when the picture has seams, it does not look proper.
Are the seams due to jpeg pixel size (of the original picture)? Suggestions would be really helpful. Is it possible to overcome this problem using vizard?
Uttams
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 01:07 PM
Which software can be used to edit .cfg (CAL3D) files luakt Vizard 4 09-12-2008 08:18 AM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 01:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 04:23 PM
Including Files that Include Other Files vjosh Vizard 1 09-21-2004 05:44 PM
