Old 04-23-2009, 06:51 AM
jdoerr jdoerr is offline
Send a message via Skype™ to jdoerr
passing node3d to c++
hello,
xabbu already asked to access the underlaying osg::Node of a node3d object. We own a vizard developer license and could use the modifier plugin, but we'll like to pass a node3d object to c++ using a .dll/.pyd file.
We're able to use PyArg_ParseTuple to parse the according PyObject*. We don't know the implementation of ob_type of node3d.
Is it possible to reach the pointer to the underlaying osg::Node?
Many Thanks for your advice
Old 04-23-2009, 04:16 PM
You cannot extract the underlying osg::Node object from the PyObject. You have to use a modifier plugin to get access to the osg::Node object. However, there is nothing stopping you from combining a modifier plugin and a python plugin into a single DLL. Here is the C++ code for a plugin that works both as a Python plugin and a modifier plugin:
#include "modifier.h"
#include "Python.h"
// DO NOT MODIFY THESE DECLARATIONS----------------
extern "C" __declspec(dllexport) void InitModifier(void *);
extern "C" __declspec(dllexport) void PerformModifier(void *);
extern "C" __declspec(dllexport) void TextureModifier(void *);
extern "C" __declspec(dllexport) void SceneModifier(void *);
extern "C" __declspec(dllexport) void CommandModifier(void *);
extern "C" __declspec(dllexport) void CloseModifier(void *);
void InitModifier(void *modifier)
	strcpy(((VizModifierObj*)modifier)->version,"Modifier Example v1.0");
	((VizModifierObj*)modifier)->dataSize = 0;
	((VizModifierObj*)modifier)->status = 1;
void PerformModifier(void *modifier)
	fprintf(stdout,"modifiying node\n");
void TextureModifier(void *modifier)
void SceneModifier(void *modifier)
void CommandModifier(void *modifier)
void CloseModifier(void *modifier)
PyObject* py_do_something(PyObject *self, PyObject *args)
	fprintf(stdout,"doing something\n");
	Py_RETURN_NONE;
static PyMethodDef ModifierMethods[] = {
	{"do_something", py_do_something, METH_VARARGS},
	{NULL, NULL}
extern "C" __declspec(dllexport) void initmodifier()
	Py_InitModule("modifier", ModifierMethods);
You would then use the following code in your Vizard script to access the plugin:
#Treat DLL as Python module
import modifier
modifier.do_something()
#Treat DLL as modifier plugin
mod = viz.addModifier('modifier.dll')
node = viz.add('gallery.ive')
node.modify(mod)
Inheritence with node3d dan12345 Vizard 1 05-23-2008 07:14 PM
Passing sensor data to C++ GUI vizmaster Vizard 2 10-05-2006 12:37 PM
passing data to viz.director vadrian Vizard 1 05-18-2005 04:30 PM
Passing arguments to vizard script hotspur1 Vizard 7 05-02-2003 03:03 PM
