Old 03-10-2009, 01:39 AM
nlfrnassimi nlfrnassimi is offline
stop physic
I have created a simple bouncing ball. I want it to stop when it reaches a particular point. But I don't know how. I'll appreciate any help.
Here is my code for ball:
viz.phys.enable()
ground = viz.add('tut_ground.wrl') # Add ground
ground.collidePlane() # Make collideable plane
ball = viz.add('ball.wrl',pos=[0,.2,6]) # Add a ball
ballPhys = ball.collideSphere(bounce = 2) # Enable physics on ball
ball.applyForce([0,.3,.2],0.5) # Apply small force for half a second
Old 03-10-2009, 12:07 PM
You could use a timer and get the position of the ball. Once its position has reached the point you specify you can either disable physics for the scene
viz.phys.disable()
or for just the ball
ball.disable(viz.PHYSICS)
Old 03-10-2009, 06:25 PM
Can you please tell me how should I use the timer to get the ball position?
Thanks alot
Old 03-11-2009, 02:43 PM
When the z coordinate of the ball is greater than 10 it will stop
def stopball():
	pos = ball.getPosition()
	if pos[2] > 10:
vizact.ontimer(0,stopball)
Old 03-11-2009, 08:26 PM
Thanks alot for your help
Stop for... loop Johannes Vizard 20 04-01-2014 01:53 AM
How to stop vizact.move Jerry Vizard 3 06-04-2009 04:25 PM
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 07:23 AM
how can I stop an action? nlfrnassimi Vizard 4 02-13-2009 12:59 AM
When a video stop ? djdesmangles Vizard 2 01-11-2007 04:15 PM
