Old 11-05-2008, 04:34 AM
Saz Saz is offline
Infinite terrain code
Hi there,
I've seen that there is a demo for infinite terrain in your downloads section, is there an accompanying code for this at all? I need to create a continuous road whereby the driver doesn't fall off the end!
Any help would be appreciated!
Old 11-05-2008, 07:19 AM
Check out this page in our documentation.
http://www.worldviz.com/vizhelp/InfiniteTerrain.htm
This explains how to use the infinite terrain plugin. Just to let you know, if you try to run that snippet of code that's provided on that page it won't find the jpg, just use one of your own. You'll also have to add the viz.go() into there.
Old 11-06-2008, 02:32 AM
Saz Saz is offline
infinite terrain
Thank you Jeff - you're a star!
Example code for VizCave stefs Vizard 6 01-08-2013 11:43 AM
How to make avatars to follow terrain while walking? yyang Vizard 1 08-04-2008 02:54 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
generate an infinite terrain vadrian Vizard 4 09-15-2004 01:09 PM
