Old 11-05-2008, 04:09 PM
vDeonne vDeonne is offline
how to tile a texture
I tried to tile the 'ground' by texturing using the code below. Rather than tile, however, the texture image is enlarged to texture the ground -- with no repeat. What code can I use to ensure that the texture image tiles rather than stretches?
ground.setPosition(0,0,0)
ground.collidePlane()
leaves = viz.add('fall-leaves.jpg')
leaves.wrap(viz.WRAP_S,viz.REPEAT)
leaves.wrap(viz.WRAP_T,viz.REPEAT)
ground.texture(leaves)
Old 11-05-2008, 05:35 PM
You need to apply a texture matrix to the ground model to scale the texture coordinates up. Here is some sample code:
#Number of times to repeat texture horizontally/vertically
NUMBER_OF_REPEATS = 10
leaves = viz.add('fall-leaves.jpg',wrap=viz.REPEAT)
#Apply a texture matrix that scales to number of repeats
ground.texmat( viz.Matrix.scale(NUMBER_OF_REPEATS,NUMBER_OF_REPEATS,1) )
3D Texture Mapping in Vizard? stefs Vizard 2 03-25-2008 03:34 AM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 12:12 PM
avatar head texture issues rconrey Vizard 3 11-17-2004 04:05 PM
How to simply texture an avatar's head with a jpeg graphic? vr_boyko Vizard 3 10-26-2004 10:44 AM
