Old 10-14-2008, 04:05 PM
vTony vTony is offline
Complete Characters Following Camera
Hi, I'm running into a weird problem when I try to use some complete character avatars. After I convert them from .max with the Cal3D exporter, they seem to follow the camera around when I use them in a Vizard script. For example, if I do:
a1 = viz.add('vcc_male.cfg')
a2 = viz.add('../avatars/confederate/casual01_m_mediumpoly/casual01_m_mediumpoly.cfg')
... a1 stays in place but a2 follows the mainview around. I'm assuming it has something to do with the way I exported the avatars from 3ds max. Any ideas on what specifically could be causing this? Thanks!
Old 10-14-2008, 04:58 PM
I think the problem might be that the scale on your avatar is very large, which makes it look like it is following the viewpoint. If you look in the vcc_male.cfg file there should be a line that looks like this:
scale=0.01
Try adding something similar to your cfg file and see if this helps.
Old 10-16-2008, 12:43 AM
That fixed it. Thanks!
Live Characters plugin Frank Verberne Vizard 7 03-01-2012 03:23 AM
How to add individual faces onto the complete characters used in Vizard? VDong Vizard 3 11-12-2008 11:05 AM
How to cut out the heads of the complete characters? VDong Vizard 2 09-26-2008 06:27 PM
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 01:07 PM
Complete Characters and 3dmax dan12345 Vizard 3 02-07-2008 07:32 PM
