Old 05-17-2016, 07:21 AM
jelly jelly is offline
Question Vizard scheduler vs Python scheduler
I have some code that is scheduling beeps respective to the onset of the script, but it seems to run everything before Vizard can load and I think that is because Vizard may not understand the scheduler?
How can I use the viztask_schedule to achieve a comparable result, after Vizard loaded the environment?
import schedule
import time
from functools import partial
import viztask
## Cue sound ###
cue = viz.addAudio('cues\dong.wav')
cueDuration = cue.getDuration()
# my specified list of timings
times = [1.76493425, 3.10174059, 4.49576803, 10.99379224, 18.84178369]
# get the starting time
start = time.time()
# define a job, i.e. play beep sound and print smth
def job(t, start):
	cue.play()
	print ('cue', ' - timing: ', t, ' - now: ', time.time()- start)
	# pop the job right away from schedule.jobs, so it runs only once
	return schedule.CancelJob
def main():
	# for each time add what to do
	for t in times:
		# using partial so i can pass arguments to job
		schedule.every(t).seconds.do(partial(job, t, start))
	# and run it inside a lop
	while True:
		schedule.run_pending()
		# schedule.jobs is just a list of jobs
		if not schedule.jobs:
			break
viztask.schedule(main())
Old 05-20-2016, 02:25 AM
The viztask library is designed to control program flow. You can wait for time to elapse, an action, event, etc. before executing more code. If you have not done so yet, take a look at the viztask documentation in the reference section and the creating a task tutorial. Use the waittime command to wait for a set time.
scheduling, timing
running multiple vizard scripts from python exhale Vizard 1 05-09-2005 05:35 AM
