Old 08-24-2008, 04:55 AM
Ravi Ravi is offline
addText problems with 3 windows
Hi
I have some problems with sowing text via viz.addTest() in a Setup with three windows. The text isn't displayed.
creating the Windows:
		# Create a new window on the left side
		self.LeftWindow = viz.add(viz.WINDOW)
		self.LeftWindow.position(0, 1)
		self.LeftWindow.size(1.0/3, 1.0)
		self.LeftWindow.visible(0,viz.SCREEN)
		self.LeftWindow.fov(FOV,ASPECT_RATIO)
		#print self.LeftWindow
		#self.CenterWindow = viz.add(viz.WINDOW)
		#self.CenterWindow.position(1.0/3, 1.0)
		#self.CenterWindow.size(1.0/3, 1.0)
		#self.CenterWindow.visible(0,viz.SCREEN)
		#self.CenterWindow.fov(FOV,ASPECT_RATIO)
		self.CenterWindow = viz.MainWindow
		#Create a new window on the right side
		self.RightWindow = viz.add(viz.WINDOW)
		self.RightWindow.position(2.0/3, 1.0)
		self.RightWindow.size(1.0/3, 1.0)
		self.RightWindow.visible(0,viz.SCREEN)
		self.RightWindow.fov(FOV,ASPECT_RATIO)
		# Create new viewports
		self.LeftView = viz.add(viz.VIEWPOINT)
		self.RightView = viz.add(viz.VIEWPOINT)
		self.CenterView = viz.add(viz.VIEWPOINT)
		#Attach the the viewports to the windows
		self.LeftWindow.viewpoint(self.LeftView)
		self.RightWindow.viewpoint(self.RightView)
		self.CenterWindow.viewpoint(self.CenterView)
		#Rotate the view so that it looks down
		#set the viewing angle for the windows
		self.LeftView.rotate(1,LEFT_ANGLE,0,0)
		self.RightView.rotate(1,RIGHT_ANGLE,0,0)
creating the text:
		self.anweisung = viz.addText("",viz.SCREEN,self.CenterWindow)
		self.anweisung.translate(0.5,0.5)
		self.anweisung.color(viz.RED)
later the anweisung.message("...") command is used to show and to change the text.
Unfortunately there is no text displayed, since we changed to the 3 window setup. With one it is working poperly.
Any idea why this isn't working?
Old 08-25-2008, 05:51 PM
If you specify a window object as the scene of a text, then you need to specify viz.ORTHO as the parent, not viz.SCREEN. Also, when adding object to the viz.ORTHO layer, the position units are in pixels, not normalized coordinates. Here is sample code:
self.anweisung = viz.addText("hello",viz.ORTHO,self.CenterWindow,fontSize=32)
self.anweisung.translate(50,50) #50 pixel from bottom left corner of window
Best Way to set up wii cursors across 2 windows shivanangel Vizard 1 03-13-2008 11:24 AM
problems with webcam plug-in v-clizzin Plug-in development 2 01-25-2008 03:06 PM
Picking in multiple windows FalconNL Vizard 1 07-02-2007 09:45 AM
Windows within windows VAmanda Vizard 5 10-31-2005 12:16 AM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
