Old 06-30-2008, 08:42 AM
GoldenSun GoldenSun is offline
Crashing when I select Tracker option
I have a script that runs fine with HMD, Full screen and stereo selections. But when I also select tracker option. I get the following error.
winviz.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
I have about 10 of the pic files loaded in the environment. so I have 10 sets of follwing:
screen1 = viz.add(viz.TEXQUAD)
screen1.translate(0.8, 1.500, -1)
screen1.setEuler(90, 0.0, 0.0)
screen1.scale(0.8, 0.5, 0.5)
image1 = viz.addTexture( 'pot.jpg' )
screen1.texture(image1)
When I remove all or some of them.. the program works with the Tracker option.
Do you know why? Is there something I can do to fix it? is there another way to post pics in the environment?
Thanks.
Old 06-30-2008, 02:42 PM
Can you post the entire script using the [code][/code] tags? Also, is your script connecting to an InterSense device?
Old 06-30-2008, 05:46 PM
Here is the entire script. Thanks for your help.
import math
#import vizmat
import vizinfo
global data
global tracking_data
viz.go(viz.PROMPT)
viz.collision(viz.ON)
viz.clearcolor
# Constants
ROTATION_INC		= 2
TRANSLATE_INC		= 0.1
#TIMERS
ANIMATE             = 0
TRACK				= 1
TRACKJOY			= 2
#in seconds
ANIMATE_RATE        = 0.01
TRACK_RATE			= 0.5
walltexture = viz.addTexture( 'brick.jpg' )
#walltexture1 = viz.addTexture( 'woodfloor2.jpg' )
#walltexture2 = viz.addTexture( 'ToolBar.jpg' )
#ceiling = viz.add('box.wrl')
#ceiling.translate(-2.200, 3.0, -2.3)
#ceiling.setScale(4.600, 0.1, 5.500)
#ceiling.color(viz.WHITE)
southwall = viz.add('box.wrl')
southwall.appearance(viz.DECAL)
southwall.translate(-2.000, 1.500, +0.450)
southwall.setScale(4.600, 3.000, 0.100)
southwall.texture( walltexture )
eastwall = southwall.clone()
eastwall.setPosition(-4.300, 1.500, -2.300 )
eastwall.setScale(0.100, 3.000, 5.500)
northwall = southwall.clone()
northwall.setPosition(-2.430, 1.500, -5.050 )
northwall.setScale(3.658, 3.000, 0.100 )
westwall = southwall.clone()
westwall.setPosition(0.300, 1.500, -2.279  )
westwall.setScale(0.100, 3.000, 3.658 )
nw1 = southwall.clone()
nw1.setPosition(-0.150, 1.500, -4.110   )
nw1.setScale(0.900, 3.000, 0.100  )
nw2 = southwall.clone()
nw2.setPosition(-0.600, 1.500, -4.558  )
nw2.setScale(0.100,3.000, 0.900  )
h1 = southwall.clone()
h1.setPosition(-2.429, 1.500, -4.110 )
h1.setScale(1.829, 3.00, 0.100 )
h2 = southwall.clone()
h2.setPosition(-1.529, 1.500, -3.208 )
h2.setScale(1.829, 3.000, 0.100  )
h3 = southwall.clone()
h3.setPosition(-3.358, 1.500, -2.278  )
h3.setScale(1.829, 3.000, 0.100  )
h4 = southwall.clone()
h4.setPosition(-1.978, 1.500, -1.350   )
h4.setScale(0.900, 3.000, 0.100 )
h5 = southwall.clone()
h5.setPosition(-0.600, 1.500, -0.450  )
h5.setScale(1.829, 3.000, 0.100  )
v1 = southwall.clone()
v1.setPosition(-1.529, 1.500, -3.658   )
v1.setScale(0.100, 3.000, 0.915 )
v2 = southwall.clone()
v2.setPosition(-3.358, 1.500, -3.658 )
v2.setScale(0.100, 3.000, 0.900 )
v3 = southwall.clone()
v3.setPosition(-0.570, 1.500, -2.278  )
v3.setScale(0.100, 3.000, 1.829  )
v4 = southwall.clone()
v4.setPosition(-1.529, 1.500, -1.829  )
v4.setScale(0.100, 3.000, 0.900 )
v5 = southwall.clone()
v5.setPosition(-3.358, 1.500, -1.350   )
v5.setScale(0.100, 3.000, 1.829  )
v6 = southwall.clone()
v6.setPosition(-2.429, 1.500, -0.450   )
v6.setScale(0.100, 3.000, 1.829  )
avatar = viz.add('vcc_male.cfg', pos=(-3.800, 0, -2.2), euler=(0,0,0) )
avatar.setScale(0.800, 0.800, 0.300  )
avatar.state(4)
textT = viz.add(viz.TEXT3D, str("T"))
textT.setScale(0.3,0.3,0.3)
textT.translate(-3.800, 1.2, -2.1)
textT.setEuler(180, 0, 0.0)
#aduck = viz.add('duck.wrl')
#aduck.setPosition(-3.800, 1.000, -2.2   )
#aduck.setScale(0.500, 0.500, 0.500  )
#aduck.setEuler(90, 0.0, 0.0)
screene = viz.add(viz.TEXQUAD)
screene.translate(-4.24, 1.500, -4.59)
screene.setEuler(-90, 0.0, 0.0)
screene.scale(0.6, 0.5, 0.5)
imagene = viz.addTexture( 'maze1\woodenWell.jpg' )
screene.texture(imagene)
screenn = viz.add(viz.TEXQUAD)
screenn.translate(-3.8, 1.500, -4.99)
screenn.scale(0.5, 0.5, 0.5)
screenn.setEuler(180, 0.0, 0.0)
imagenn = viz.addTexture( 'maze1\clock.jpg' )
screenn.texture(imagenn)
screenw = viz.add(viz.TEXQUAD)
screenw.translate(0.24, 1.500, -3.7)
screenw.setEuler(90, 0.0, 0.0)
screenw.scale(0.5, 0.5, 0.5)
imagew = viz.addTexture( 'maze1\CandlePlate.jpg' )
screenw.texture(imagew)
screenw1 = viz.add(viz.TEXQUAD)
screenw1.translate(0, 1.500, -4.05)
screenw1.scale(0.3, 0.5, 0.5)
screenw1.setEuler(180, 0.0, 0.0)
imagenw1 = viz.addTexture( 'maze1\OrangeChair.jpg' )
screenw1.texture(imagenw1)
screenh2 = viz.add(viz.TEXQUAD)
screenh2.translate(-0.85, 1.500, -3.15)
screenh2.scale(0.3, 0.5, 0.5)
imageh2 = viz.addTexture( 'maze1\plant1.jpg' )
screenh2.texture(imageh2)
screenh4 = viz.add(viz.TEXQUAD)
screenh4.translate(-1.97, 1.500, -1.42)
screenh4.scale(0.5, 0.4, 0.5)
imageh4 = viz.addTexture( 'maze1\curvydesk.jpg' )
screenh4.texture(imageh4)
screenv1 = viz.add(viz.TEXQUAD)
screenv1.translate(-1.58, 1.500, -3.658)
screenv1.setEuler(90, 0.0, 0.0)
screenv1.scale(0.6, 0.5, 0.5)
imagev1 = viz.addTexture( 'maze1\RedWine.jpg' )
screenv1.texture(imagev1)
screenv3 = viz.add(viz.TEXQUAD)
screenv3.translate(-0.623, 1.500, -2.7)
screenv3.setEuler(90, 0.0, 0.0)
screenv3.scale(0.6, 0.5, 0.5)
imagev3 = viz.addTexture( 'maze1\limens.jpg' )
screenv3.texture(imagev3)
screenv4 = viz.add(viz.TEXQUAD)
screenv4.translate(-1.59, 1.500, -1.8)
screenv4.setEuler(90, 0.0, 0.0)
screenv4.scale(0.5, 0.4, 0.5)
imagev4 = viz.addTexture( 'maze1\Glasses.jpg' )
screenv4.texture(imagev4)
screenexit = viz.add(viz.TEXQUAD)
screenexit.translate(-2.36, 1.500, -0.45)
screenexit.setEuler(90, 0.0, 0.0)
screenexit.scale(0.3, 0.5, 0.5)
imageexit = viz.addTexture( 'maze1\cnotes.jpg' )
screenexit.texture(imageexit)
text = viz.add(viz.TEXT3D, str("STOP"))
text.setScale(0.3,0.3,0.3)
text.translate(0.5, 1.5, .4)
text.setEuler(90, 0, 0.0)
text1 = viz.add(viz.TEXT3D, str("1"))
text1.setScale(0.3,0.3,0.3)
text1.translate(0.25, 1.5, -3.95)
text1.setEuler(135, 0, 0.0)
text2 = viz.add(viz.TEXT3D, str("2"))
text2.setScale(0.3,0.3,0.3)
text2.translate(-4.12, 1.5, -5.)
text2.setEuler(-135, 0, 0.0)
text3 = viz.add(viz.TEXT3D, str("3"))
text3.setScale(0.3,0.3,0.3)
text3.translate(-1.58, 1.03, -3.6)
text3.setEuler(90, 0, 0.0)
text4 = viz.add(viz.TEXT3D, str("4"))
text4.setScale(0.3,0.3,0.3)
text4.translate(-0.6, 1.5, -3.05)
text4.setEuler(135, 0, 0.0)
text5 = viz.add(viz.TEXT3D, str("5"))
text5.setScale(0.3,0.3,0.3)
text5.translate(-1.69, 1.5, -1.42)
text5.setEuler(45, 0, 0.0)
viz.translate(viz.HEAD_POS,0.5,0,0)
viz.MainView.setEuler(-90,20,0)
subject = viz.get(viz.INITMESG) #use it to enter subject number
#tracking_data = open('tracking_'+str(subject)+'.txt', 'w') #create a tracking data file
data = viz.get(viz.HEAD_POS)
if viz.get(viz.TRACKER):
	intersense = viz.add('intersense.dls')
	viz.tracker()  #?
	intersense.reset()  #reset intersense tracking data to 0 initial
	viz.eyeheight(1.0)
	#viz.link(intersense,viz.MainView)
	tracking = 1
	tracking = 0
	#viz.collision(viz.ON)
if viz.get(viz.OPTION1):
	import vizjoy
	#import viztracker
	joy = vizjoy.add()
	#tracker = viztracker.add()
	#viz.link(tracker,viz.MainView)
	if not joy.valid():
		joy = None
	joy = None
# Callback function to handle expiration timers
def mytimer(num):
	if num == ANIMATE:
		if joy:
			#Use joystick to move and turn
			pos = joy.getPosition()
			x = pos[0]
			y = pos[1]
			if math.fabs(y) > 0.2:
				viz.move(0,0,-y*0.01)
			if math.fabs(x) > 0.2:
				viz.rotate(viz.BODY_ORI,x*1,0,0)
	if num == TRACK:
		#global data
		data = intersense.getData()  # Access the raw data from the sensor
		#data = v.getPosition()
		tracking_data.write(str(viz.tick())+','+str(data)+'\n')
		#print data  # Print the array of data
	if num == TRACKJOY:
		#global data
def mykeyboard(key):
	if key == 'j':
		print "writing to file for joy"
		viz.starttimer(TRACKJOY,TRACK_RATE, viz.FOREVER)
		vizinfo.add('Joystick Tracking...')
	if key == 'i':
		print "writing to file for intersense"
		viz.starttimer(TRACK,TRACK_RATE, viz.FOREVER)
		vizinfo.add('Intersense Tracking...')
	if key == 'p':
		print viz.get(viz.HEAD_POS)
viz.callback(viz.KEYBOARD_EVENT, mykeyboard)
viz.callback(viz.TIMER_EVENT, mytimer)
if joy:
	viz.starttimer(ANIMATE,ANIMATE_RATE,viz.FOREVER)
	tracking_data = open('joytracking_'+ str(subject)+'.txt', 'w') #create a tracking data file
if tracking:
	tracking_data = open('is900tracking_'+ str(subject)+'.txt', 'w') #create a tracking data file
Old 06-30-2008, 06:55 PM
The crash is probably related to the InterSense. The drivers provided by InterSense will crash sometimes when searching for a connected device. The solution is to explicitly define which port the InterSense is connected to. For example, if the device is connected on COM port 1, add the following line of code to your script:
PORT_INTERSENSE = 1
Old 07-01-2008, 11:06 AM
Thanks! It works great now.
tracker commands frequency over the JimB Vizard 3 03-07-2008 09:33 AM
Interface with Tobii Eye Tracker Uttama_vizard Precision Position Tracker (PPT) 1 12-12-2007 11:31 AM
Can Vizard interact with the Arrington eye tracker? Deltcho Vizard 1 09-18-2007 02:38 PM
