Old 08-07-2008, 01:18 PM
Enlil Enlil is offline
Reading bone movement from animations
As the title suggest, is there an easy way to get at the bone movement of the animations of an avatar?
Christian
Old 08-07-2008, 03:56 PM
Do you just need to get the bone position/rotation info? If so, you can use the bone.getPosition() and bone.getQuat() functions to get the current values.
Old 08-10-2008, 12:37 AM
We were hoping to get the positions at some arbitrary point in order to apply inverse kinematics (from some other software) to combine the animation and some other motion (say, the movement of an arm based on a tracker). Is such data easily availible?
Christian
Old 08-11-2008, 12:53 PM
You can manually set the time of an animation and then get the position of the bone. Have a look at the avatar.setAnimationTime() command.
Old 08-14-2008, 11:49 AM
I think that may work, thanks. Is there any way to tell what the length of an animation is?
Christian
Old 08-14-2008, 03:29 PM
You can use the avatar.getDuration() command to get the length of an animation.
animations dan12345 Vizard 3 07-14-2008 12:43 PM
vcc avatars: defining bone length bjgold Vizard 1 08-08-2007 12:24 PM
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
loading CAF animations vadrian Vizard 1 06-02-2005 05:38 PM
avatar bone movement epl Vizard 3 05-03-2004 05:27 PM
