Old 05-02-2003, 08:27 AM
hotspur1 hotspur1 is offline
chaging screen resolutions
Is there a way to change screen resolution from within Vizard?
I am working in a scenario where I initially want to have higher res (probably SVGA or maybe XGA but when I call Vizard, I need to get resolution down to VGA so I can use my Kaiser HMD. I'd need to set the res back when I am done with my Vizard script.
Are there any calls or workarounds in Vizard for doing this?
Andy
Old 05-02-2003, 02:38 PM
Hi Andy,
There isn't any built in function to change the screen resolution within Vizard. However, if you know a little bit of windows programming, it would be very easy to create a Vizard plugin to accomplish this. Here's some windows code that will change the screen resolution to 800x600:
DEVMODE dmScreenSettings;
memset(&dmScreenSettings,0,sizeof(dmScreenSettings ));
dmScreenSettings.dmSize=sizeof(dmScreenSettings);
dmScreenSettings.dmPelsWidth = 800;
dmScreenSettings.dmPelsHeight = 600;
dmScreenSettings.dmFields=DM_PELSWIDTH|DM_PELSHEIG HT;
ChangeDisplaySettings(&dmScreenSettings,0);
The following code will return you back to the original resolution:
ChangeDisplaySettings(NULL,0);
Good luck!
-- farshid
