Old 01-09-2008, 06:39 AM
krimble krimble is offline
animate cal3d bones
Hi all,
What I have is a cal3d avatar with a peoplemaker morph (for a talking mouth).
The avatar has to perform an animation: lean forward - back the origin - lean backward back to origin - lean left - back to origin - lean right and back to origin.
The bone that I want to rotate is one of the spineBones.
This is the code-part where i'm talking about:
viz.starttimer(TIMER_BODY_MOVEMENT, .03, 1)
def onTimerEvent(id) :
if id == TIMER_BODY_MOVEMENT :
    spine02.rotate(10,0,0)
viz.callback(viz.TIMER_EVENT,onTimerEvent)
What's happening now: the bone seems to snap to the new position, with <bone>.setEuler() it's doing the same.
How can I make this a smooth animation?
Thanks!
Old 01-10-2008, 03:23 AM
Anybody?
Shorter question: How do I animate a cal3d bone. ( not the neckBone )?
Thanks!
Old 01-10-2008, 04:20 PM
I've attached a sample script that creates a custom vizact action that animates a bone. The code at the bottom of the script shows how to use the action. This action will be included in the vizact library in the next release of Vizard. Let me know if anything is unclear.
Code for creating action that animates a bone rotating
_paramval_ = vizact._paramval_
_paramlist_ = vizact._paramlist_
VizCubicQuatInterpolator = vizact.VizCubicQuatInterpolator
VizLinearQuatInterpolator = vizact.VizLinearQuatInterpolator
def boneSpinTo(bone,mode=viz.ABS_PARENT,quat=None,euler=None,axisAngle=None,speed=None,time=None,p1=None,p2=None):
	bla = viz.ActionData()
	bla.bone =  bone
	bla.mode = mode
	bla.speed = speed
	bla.time = time
	bla.quat = quat
	bla.euler = euler
	bla.axisAngle = axisAngle
	bla.p1 = p1
	bla.p2 = p2
	bla.actionclass = VizBoneSpintToAction
	return bla
class VizBoneSpintToAction(viz.ActionClass):
	def begin(self,object):
		self.elapsed = 0.0
		self.duration = 0.0
		#If bone is not a Vizard bone object, assume it is string and get bone from name
		bone = _paramval_(self._actiondata_.bone,object)
		if isinstance(bone,viz.VizBone):
			self.bone = bone
			self.bone = object.getBone(bone)
		#Make sure bone is valid
		if not self.bone:
			self.end(object)
			return
		#Lock the bone for animating
		self.bone.lock()
		#Get coordinate frame mode for bone rotations
		self.mode = _paramval_(self._actiondata_.mode,object)
		#Get begin and end rotation
		beginQuat = self.bone.getQuat(self.mode)
		if self._actiondata_.quat is not None:
			self.endQuat = _paramlist_(self._actiondata_.quat,object)
		elif self._actiondata_.euler is not None:
			self.endQuat = vizmat.EulerToQuat(_paramlist_(self._actiondata_.euler,object))
		elif self._actiondata_.axisAngle is not None:
			self.endQuat = vizmat.AxisAngleToQuat(_paramlist_(self._actiondata_.axisAngle,object))
			self.end(object)
			return
		#Compute whether animation duration is based on time or speed
		speed = _paramval_(self._actiondata_.speed,object)
		time = _paramval_(self._actiondata_.time,object)
		if time is not None:
			self.duration = time
		elif speed is not None:
			self.duration = vizmat.QuatDiff(beginQuat,self.endQuat) / speed
		#Make sure duration is valid
		if self.duration <= 0.0:
			self.bone.setQuat(self.endQuat,self.mode)
			self.end(object)
			return
		#Check if we are using linear or cubic interpolation
		p1 = _paramlist_(self._actiondata_.p1,object)
		p2 = _paramlist_(self._actiondata_.p2,object)
		if p1[0] is not None and p2[0] is not None:
			interpolator = VizCubicQuatInterpolator(p1[0],p2[0])
			interpolator = VizLinearQuatInterpolator()
		interpolator.init(beginQuat,self.endQuat)
		self.interpolate = interpolator.interpolate
	def update(self,elapsed,object):
		self.elapsed += elapsed
		p = self.elapsed / self.duration
		if p >= 1.0:
			self._overtime_ = self.elapsed - self.duration
			self.end(object)
			return
		self.bone.setQuat(self.interpolate(p),self.mode)
model = viz.add('vcc_female.cfg',pos=(0,0,5),euler=(180,0,0))
lookRight = boneSpinTo('Bip01 Spine1',mode=viz.AVATAR_LOCAL,euler=(45,0,0),speed=90)
lookLeft = boneSpinTo('Bip01 Spine1',mode=viz.AVATAR_LOCAL,euler=(-45,0,0),speed=90)
vizact.onkeydown(viz.KEY_RIGHT,model.runAction,lookRight,pool=1)
vizact.onkeydown(viz.KEY_LEFT,model.runAction,lookLeft,pool=1)
Old 01-11-2008, 05:31 AM
Thanks man!!!
I'll take a look at it as soon i've got the time.
Old 05-07-2008, 08:51 AM
Karla Karla is offline
Example request for vizact.boneSpinTo()
I noticed that for the Q1 2008 Release of Vizard, vizact.boneSpinTo() is listed as an addition.
vizact.boneSpinTo() action for animating avatar bones
I am running vizard_3.00.2701. I cannot find any additional information about vizact.boneSpinTo() in the Help Documentation.
Can someone please post an example of how to use vizact.boneSpinTo() without including the sample script as posted above? For now I'm using the sample script but more condensed code would be preferable.
Thanks!
~Karla
Old 05-07-2008, 10:40 AM
Here is a short sample:
lookLeft = vizact.boneSpinTo('Bip01 Head',mode=viz.AVATAR_LOCAL,euler=(-90,0,0),speed=90)
avatar.runAction(lookLeft)
And here is the documentation for the command:
<vizact>.boneSpinTo(
    bone
    mode = viz.ABS_PARENT
    quat = None	    # Keyword argument
    euler = None	    # Keyword argument
    axisAngle = None	    # Keyword argument
    speed = None	    # Keyword argument
    time = None	    # Keyword argument
bone
An Avatar bone object or the name of a bone.
The transformation mode to apply the rotations with
quat = None
The quaternion rotation to spin to
euler = None
The euler rotation to spin to
axisAngle = None
The Axis-Angle rotation to spin to
speed = None
The speed to spin at in degrees/sec
time = None
The amount of time to spin for
cal3d exporter issue reiverlass Vizard 4 07-18-2007 01:08 PM
importing avatars with cal3d marcoleon Vizard 15 04-28-2006 05:48 PM
importing cal3d in 3ds? shai Vizard 1 11-01-2004 11:19 AM
Using Cal3d Avatars zachhendershot Vizard 4 01-27-2004 11:26 AM
Linking avatar 'bones' to a position tracker. zachhendershot Vizard 3 11-19-2003 10:26 PM
