Old 05-07-2008, 06:05 PM
joeymax joeymax is offline
Unhappy fixing alpha textured objects
Hi there
i have created a tree object in 3dsmax which has a diffuse and alpha texture applied. when i view the object in vizard, there seems to be some problems.
when there is a few alpha textured objects on screen at once they seem to flicker, sometimes they have their transparency, sometimes they dont, and sometimes a grey/white border appears around the object (when that part of the object should be see-through).
I think this has something to do with draworder maybe??
I can send you my scene (along with the textures) but its in a 6mb zip folder (they only let you upload 1mb on here)
Ideally what i want to be able to do is create a scene with lots of trees (2d alpha textured billboards) and i want them to work properly, so that there is no conflicts with other objects in the scene, no pop-ups/flickering etc.
Again.. probably easier to explain if i send you my file.
Old 05-07-2008, 10:12 PM
k_iwan k_iwan is offline
I use PNG image format with transparency on the image. It works well.
Old 05-08-2008, 05:54 AM
nige777 nige777 is offline
RE:Alpha
Hi Joey,
This is a draworder issue i think mate. High numbers are drawn first and low last (i think thats right!?), so if your alpha's are showing the background colour instead of what is behind them (white or black), try increasing their draworder number.
Old 05-08-2008, 06:24 AM
thanks... I'll try using PNG's
can i simply apply the PNGs to objects in max and still get the transparency, or do i have to apply the PNGs to the model through vizard. if so I guess i still need to apply a uwv map modifier before i export so the texture looks correct?
..is there no way to correct the 'flickering' problem when using standard diffuse/alpha texture?
thanks again
Old 05-08-2008, 06:26 AM
sorry i posted that last message before noticing your reply nige, i'll try that first.. cheers
Old 05-09-2008, 11:31 PM
Thumbs up
thanks guys! it works perfect now
if anyone else has suffered the same problem, simply texture the model with a PNG texture (with transparency) then in vizard make sure you set the draworder to something high...
tree = viz.add('tree_1.ive')
tree.draworder(1000)
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 05:19 PM
Alpha and Texturing questions Manny Vizard 3 03-08-2007 11:55 AM
putting objects on the screen jargon Vizard 7 05-24-2005 11:31 AM
Overlaying Textures with Alpha Masks vjosh Vizard 7 04-06-2005 07:46 PM
