Old 04-28-2008, 12:28 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code
Vizard's Task feature makes writing code that you want to happen over time easier. Tasks are functions that pause as they wait for some condition (like 2 seconds to pass or spacebar pressed) before continuing with their local variables preserved.
Say you want a traffic light that changes color every second. Using timers, you could create a Vizard timer event that sets the next color based on a global variable that remembers the previous color. Or you could create a self-contained task function.
import viztask
ball = viz.add('white_ball.wrl', pos=[0, 1.7, 1])
def doStoplight(theBall):
	while True:
		theBall.color(viz.GREEN)
		yield viztask.waitTime(1)
		theBall.color(viz.YELLOW)
		yield viztask.waitTime(.5)
		theBall.color(viz.RED)
viztask.schedule(doStoplight(ball))
First, the code imports the viztask module of Vizard that provides the Task functionality. After adding our stoplight ball we define our task function just like a normal function. The function becomes a task function because of the "yield" statement. The yield statement indicates when the task pauses and waits for some seconds. When the wait time is up, the next lines of code are run until we hit another yield statement. The last line passes an instance of our "doStoplightTask" to the scheduler. The scheduler triggers the execution of the task. Tasks must be scheduled to run, they can't be called like normal functions.
Creating tasks that wait for other tasks can simplify programs that progress though a series of states. Research experiments often progress though these states: get parameters; present a number of trials; finalize data recording. Here is a experiment framework using tasks:
import viztask
def doExperimentTask():
	NUMBER_OF_TRIALS = 3
	for i in range(NUMBER_OF_TRIALS):
		yield doTrialTask(i)
	print 'experiment done'
viztask.schedule(doExperimentTask())
def doTrialTask(trialNumber):
	#present stimulus
	yield viztask.waitKeyDown(' ') #gather response
	#record data
	print 'trial number', trialNumber
More information regarding Vizard task is in your Vizard help file and at this address:
http://www.worldviz.com/vizhelp/VizTask_basics.htm
Old 04-29-2008, 11:28 AM
Andrey Andrey is offline
Viztask
Is it possible to use viztask in order to delay onCollide events? - i.e. to create the time interval after the collision when objects do not produce collision event?
Old 04-29-2008, 11:39 AM
theuberk theuberk is offline
A tip of the month is an excellent idea. Thanks!
Old 04-29-2008, 12:27 PM
Andrey,
Tasks can wait for a number of conditions, including events like COLLIDE_BEGIN_EVENT. Perhaps you want to do something like this?
import viztask
def doSomethingWhenCollidingTask():
	while True:
		yield viztask.waitEvent(viz.COLLIDE_BEGIN_EVENT)
		print 'collidy !!!'
		#do something
		yield viztask.waitTime(2) #ignore events for 2 seconds
viztask.schedule(doSomethingWhenCollidingTask())
Old 05-02-2008, 04:22 PM
k_iwan k_iwan is offline
Thank you for sharing. I'm using director for task scheduling... Is there any different?
Old 05-02-2008, 04:30 PM
Unless you are performing blocking operations (i.e. reading from file or socket) I strongly recommend against using director functions. Director functions use real operating system threads, therefore they are not deterministic and you could experience synchronization problems.
Vizard and Augmented Reality realvision Vizard 4 04-04-2008 10:59 AM
Vizard won't run wouters Vizard 5 02-05-2008 11:12 AM
Vizard 3.0 beta activation code vnacooper Vizard 3 09-21-2006 12:03 PM
wxPython with Vizard farshizzo Vizard 18 09-29-2005 08:49 AM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
