Old 06-04-2008, 05:12 AM
krimble krimble is offline
using i900 joystick in a taskFunction
What I'm trying to do is, using the buttons on the joystick to scale my virtual world. I'm using a task know, but it seems that the event doesn't get triggered when using "viz.SENSOR_UP_EVENT". If I use "viztask.waitSensorDown" then I don't know what to put in it as a button. I've tried the state things from the manual "joystickSensor.get()[7]" but it doesn't give me the actual pressed button wich I have to put in, right?
def scaleOnSensorEvent() :
	dataObject = viz.Data
	sensorData = joystickSensor.get()
	while True :
		yield viztask.waitEvent(viz.SENSOR_UP_EVENT, dataObject)
#		yield viztask.waitSensorDown(joystickSensor, button??, dataObject)
		print "something"
if viz.get(viz.TRACKER):
	headSensor = viz.add('intersense.dls')
	viz.tracker()
	headSensor.reset()
	joystickSensor = viz.add('intersense.dls')
	viz.tracker()
	joystickSensor.reset()
viztask.schedule(scaleOnSensorEvent)
thanks for your help
Old 06-04-2008, 10:24 AM
The intersense.dls plugin does not generate sensor up/down events. You need to manually check the button state by examining the value at index 7 of the data array. The documentation for the intersense plugin has sample code showing how to check for the button state of the joystick.
Old 06-06-2008, 01:52 AM
Thank you,
I've used a timer now, and it works. It would be handy though to be able to use a task with the IS-900 joystick (wand). The use of tasks makes it a whole lot easier, great concept!
Old 06-10-2008, 10:20 AM
You can create your own custom task conditions. For example, here are two conditions that wait for an IS900 button to be pressed or released:
class waitIS900Down( viztask.Condition ):
    def __init__( self, sensor, button ):
        self._sensor = sensor
        self._button = button
    def update( self ):
        return int(self._sensor.getData()[7]) & self._button
class waitIS900Up( viztask.Condition ):
    def update( self ):
        return (int(self._sensor.getData()[7]) & self._button) == 0
Here is code that shows how to use it:
yield waitIS900Down(isense,1)
print 'Button 1 pressed'
yield waitIS900Up(isense,1)
print 'Button 1 released'
Joystick Navigation Vinicius Lima Vizard 7 10-23-2007 10:42 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 10:56 AM
problem with joystick data and input dialog box baf1 Vizard 4 03-03-2005 08:00 AM
Another Joystick Question Plasma Vizard 3 02-03-2004 11:16 AM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 07:08 PM
