Old 04-07-2008, 03:01 PM
Uttama_vizard Uttama_vizard is offline
Timing issue
While working with avatars moving dynamically on the virtual screen, I want to record the x,y,z coordinates of say 'head' of an avatar. For this, I am using
print "male1_head_position:", head1.getPosition(viz.AVATAR_WORLD)
This is giving me the coordinates.
In addition, I want to record the system time instantaneously, so that I can correlate the 3D coordinates of say, head of an avatar at a particular instant with some tracking data. From the "help" coming with Vizard, I am getting the elasped time, but, I am not getting the particular instant associated with a particular 3D position of an object.
Can any one suggest me a solution to this?
Thanks in advance.
Uttama
Old 04-07-2008, 03:03 PM
Use viz.getFrameTime() to get the current absolute time of the frame.
Old 04-07-2008, 03:17 PM
Timing Issue
Thank you so much.
But, I am getting this display as output
male1_head_position: [0.0054466063156723976, 1.7178937196731567, -1.9990379810333252]
79.6599115251
2
158.816147862
'2' indicates my second looping of the program. In fact, it shows that the frame time is doubled in the second looping of the program.
What, I wanted is to display the system time in hrs:mins:secs format.
Your suggestions are very helpful.
Uttama
Old 04-07-2008, 03:30 PM
The viz.getFrameTime() function returns the current time in seconds. You can use the time module to format it for display. The following code will format the time to hrs:min:secs:
import time
print time.strftime('%H:%M:%S',time.gmtime(viz.getFrameTime()))
Old 04-07-2008, 03:38 PM
Timing Issue
I am getting the output as
00:01:19
2
00:02:39
3
But, this is the elasped time. I wanted the system time in hrs:mins:secs format.
Uttama
Old 04-07-2008, 03:40 PM
Have a look at the Python documentation for the time module. It describes all the functionality you need. In this case you would use the time.localtime() function:
time.strftime('%H:%M:%S',time.localtime())
Timing jaclyn.bill Vizard 2 10-19-2007 03:34 AM
stereo projection issue asimbh Vizard 3 10-05-2007 10:22 AM
cal3d exporter issue reiverlass Vizard 4 07-18-2007 12:08 PM
viewing issue. cantwelljm Vizard 3 03-29-2006 12:03 PM
vizard 2.5 compatability issue shai Vizard 3 08-10-2005 04:35 PM
