Old 03-03-2008, 04:50 AM
dan12345 dan12345 is offline
small indentation question
for some reason, vizard started showing blue lines before a beginning of
lines of code, signifying wrong indentation, eventhough the indentation is OKAY.
This also causes the script not to run, with an indentation error.
in order to fix it, each time i have to backspace and then space to the
same position, and this usually fixes it.
Why did this start happening? how do i solve it?
thanks!
Old 03-03-2008, 04:57 AM
mspusch mspusch is offline
is it possible that you are mixing whitespace and tabs?
this would make the code look correct, but as python recognizes the difference between tabs and whitespace, this causes indentation errors.
to see what is going on, under the "view" menu, switch "whitespace" on.
Another color question mjabon Vizard 4 07-31-2007 03:04 PM
question about yaw, pitch, roll TunTun Vizard 2 05-23-2007 12:46 PM
Units Question Plasma Vizard 4 02-24-2004 09:54 AM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 07:08 PM
