Old 02-14-2008, 10:00 AM
nige777 nige777 is offline
Normal Maps
Hi all,
I take it that as i can find no mention of normal maps in the vizard documentation that it is not possible to use them? Is this the unfortunate truth?
Regards
Nigel
Old 02-14-2008, 03:38 PM
Vizard has built-in support for vertex/fragment shaders, which means you can implement all sorts of advanced rendering techniques. I've attached a zip file that contains a script that implements normal-bump mapping. You can use the arrow keys to move the light around.
Old 02-14-2008, 05:59 PM
Thank you
Thanks for the prompt response farshizzo, again, it's great to know it's possible . While your shader works well with the provided osg, I am having a bit of difficulty using it with my model. Normal maps were created in Max (baked from high poly model) using texture channel 2. Trouble is I get - ## WARNING: Could not generate tangent/binormal data for geometry 'orig_orig_orig_blue', where orig_orig_blue is a material created by max when it baked the normal map. What is the best work flow in your opinion, I notice that only the diffuse map is loaded with the ball.osg, is that how it needs to be done?
Thanks in advance,
Old 02-15-2008, 12:09 PM
Post Normal Maps
Update on the last message. Got rid of the warning by using a diffuse texture map (rather than the default max shader) and removed the normal map from the model but to no avail, the model is invisible, if i comment out the shader code it's displayed but the diffuse mapping is messed up . I feel I may be missing something really obvious here (too many late nights infront of the computer maybe ).
Has anybody else had experience/success using normal mapping?
Thanks for your patience.
Old 02-15-2008, 03:48 PM
Is your model invisible or just black? How large is your model? That sample script assumes the model is very small. If your model is larger then the attenuation on the point light might not reach it.
Old 02-15-2008, 07:07 PM
Me again!
Hi farshizzo,
Unfortunately the model is invisible, when i comment out the shader code the normal is mapped correctly now tho . I have taken the liberty of attaching the code and osg in the hope that you may be able to throw some light on this problem for me.
Kind regards
environment maps, scenes, and you! vadrian Vizard 1 01-12-2005 05:04 PM
generating images for panoramas using cube maps bailenson Vizard 5 09-08-2004 09:32 PM
