Old 02-15-2008, 02:26 AM
Dave Dave is offline
Biohead animation
Hi – I am having problems making a biohead look at things.
With an ordinary Vizard avatar no problem:-
male = viz.add('male.cfg')
look_right = vizact.headto(-45,-30,0,15,'skel_Head')
male.addAction(look_right)
works a treat
However, if I attach a biohead:-
head = viz.addFace( 'biohead_talk.vzf' )
male.setFace( head, 'skel_Neck', 'skel_Head')
nothing happens
If I try and lock the head – head.lock() then I get an error message VizFace has no attribute lock.
I can perform the animation successfully by using the Neck bone – ie.
look_right = vizact.headto(-45,-30,0,15,'skel_Neck')
but then the arms go with it – and I cannot seem to decouple the arms from the neck.
I know that it is probably a simple thing but how do I just move the biohead by itself or decouple the arms etc from the neck.
Old 02-15-2008, 03:37 PM
Please have a look at the documentation for the setFace command. You are passing the head/neck bone arguments in reverse order. Either way, you don't even need to specify them, the default values should work. Simply change the line:
to:
male.setFace(head)
Old 02-17-2008, 07:13 AM
Thanks Farshizzo - thought it would be something simple that I was missing. In the actual routine I am using a different avatar body and so have non-default head and neck bone arguments, but putting them in the correct order works fine - thanks.
Animation Tracks.... k_iwan Vizard 2 03-26-2007 06:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 03:11 PM
animation sequence pkhoosh Vizard 2 01-23-2006 09:03 AM
avatar animation problems jrodman Vizard 1 01-18-2006 10:12 AM
Making an avatar speak while performing an idling animation vr_boyko Vizard 1 10-05-2004 05:23 PM
