Old 02-14-2008, 10:16 PM
asimbh asimbh is offline
emagin with quadro FX 4600
I was wondering if someone has used the Emagin with Quadro FX 4600 and managed to get stereoscopic output i.e. 3D. Emagin works fine with my laptop with Quadro FX 350M however I couldn’t manage to make it work properly with the aforementioned card.
A prompt response will highly appreciated.
Old 02-15-2008, 06:59 PM
Are you enabling quad buffer in Vizard by using the viz.QUAD_BUFFER flag?
viz.go(viz.QUAD_BUFFER)
Also, you need to enable stereo in your graphics card settings. I've attached a screenshot showing which settings you need to enable.
Old 02-16-2008, 08:08 AM
Yes, quad buffer is enabled through the Vizard and stereo is enabled with the graphics card's settings similar to the image attached. During the simulation I can see left/right flickering image which I guess represents that graphics card is working.
However same flickering image appears on both Emagin screens instead of appearing on separate screens to provide depth. I have kind of tried all possible settings but still not successful. I wonder if there’re settings with Emagin that needs to be played with?
Old 02-19-2008, 03:38 PM
If the Vizard window is flickering, then that means Vizard is working correctly. Are you running at 800x600 resolution? There are some troubleshooting tips in the following thread that might be worth a try: http://www.worldviz.com/forum/showthread.php?t=649
eMagin spacefarer Vizard 9 04-10-2008 11:10 AM
nVisorSX vs eMagin betancourtb82 Vizard 4 09-20-2007 03:18 PM
Emagin Z800 problem michaelinTX Vizard 5 07-12-2007 06:18 AM
