Old 10-25-2007, 06:44 PM
mjabon mjabon is offline
Tickle2 Demo not working in Vizard 3.0
Hi. With our new version of Vizard Tickle2.py is not working. It gives the error:
C:\Program Files\WorldViz\Vizard30\bin\lib\whrandom.py:38: DeprecationWarning: the whrandom module is deprecated; please use the random module
DeprecationWarning)
** ERROR: Failed to load plug-in: 'hd.dlm'
I tried adding the line
viz.setOption('hd.version',1)
This did not work. Furthermore I wrote my own script that works just fine with the haptic pen and in it all I say is:
 import hd
The code works in 2.5. I have attached the file.
Thanks.
Old 10-26-2007, 09:33 AM
Does the Tickle2.py script contain a local version of the hd.dlm file?
Old 10-31-2007, 02:25 PM
v-zbigy v-zbigy is offline
I am Pablo, and am the one trying to debug this now.
What do you mean a local version of the file within the script? Do you mean a local version of the file within the folder the script is running from?
Pablo
Old 10-31-2007, 02:31 PM
Yes, is there a copy of the hd.dlm file in the directory of the tickle script?
Old 10-31-2007, 02:34 PM
yes.. it does. Is it supposed to?
Old 11-01-2007, 10:22 AM
No, you should remove the file since it is already included with Vizard 3.0. If there happens to be a hd.py and hd.pyc file in the same directory as the script you should remove them as well.
