Old 08-16-2007, 12:04 PM
Vinicius Lima Vinicius Lima is offline
Viewpoint control
I am working using the viewpoint control tutorial and when I am trying to make the car I modeled in 3d Max I am running into coordinate problems. It seems to work when I have the object positioned at 0,0,0 but when I move it somewhere else, the viewpoint is no longer inside the car. Here is my script:
#Changing the background color to SKYBLUE
viz.clearcolor(0.5,0.5,1)
#Defining the move and the turn speeds
MOVE_SPEED = 5
TURN_SPEED = 60
#Adding the objects to the world
ground = viz.add('ground.osg')
car = viz.add('car.osg')
#Getting main viewpoint object
def mytimer(num):
if viz.iskeydown(viz.KEY_UP):
view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_OR I)
elif viz.iskeydown(viz.KEY_DOWN):
view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
if viz.iskeydown(viz.KEY_RIGHT):
view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BOD Y_ORI,viz.RELATIVE_WORLD)
view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE _WORLD)
updatecar()
def updatecar():
car.translate(view.get(viz.HEAD_POS))
car.rotate(view.get(viz.BODY_AXISANGLE))
car.translate(0.35,-1.2,0.2,viz.RELATIVE_LOCAL)
#def updatecar():
# car.translate(view.get())
# car.rotate(view.getAxisAngle(viz.BODY_ORI))
# car.translate(0.35,-1.2,0.2,viz.RELATIVE_LOCAL)
def mousemove(e):
euler = view.getEuler(viz.HEAD_ORI)
euler[0] += e.dx*0.1
euler[1] += -e.dy*0.1
euler[1] = viz.clamp(euler[1],-85.0,85.0)
view.rotate(euler,viz.HEAD_ORI)
def mousedown(button):
view.reset(viz.HEAD_ORI)
elif button == viz.MOUSEBUTTON_RIGHT:
view.reset(viz.BODY_ORI|viz.HEAD_POS)
updatecar()
viz.callback(viz.MOUSE_MOVE_EVENT,mousemove)
viz.callback(viz.MOUSEBUTTON_EVENT,mousedown)
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
viz.restrictmouse(viz.ON)
Vinicius
Old 08-16-2007, 03:24 PM
Can you please repost the code using the [code][/code] tags. It will preserve the formatting and make it easier for me to test your script. Thanks.
Old 08-16-2007, 03:30 PM
PHP Code:
import viz
viz
.go()
MOVE_SPEED = 5
TURN_SPEED
= 60
def mytimer(num):
    if
view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
    if
view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
updatecar()
def updatecar():
#def updatecar():
def mousemove(e):
#euler = view.getEuler(viz.HEAD_ORI)
euler = view.get(viz.HEAD_EULER)
euler[0] += x*0.1
    euler
[1] += -y*0.1
    euler
[1] = viz.clamp(euler[1],-90.0,90.0)
    if
updatecar()
viz.callback(viz.MOUSEMOVE_EVENT,mousemove)
viz.mousedata(viz.RELATIVE,viz.RELATIVE)
viz.setMouseOverride()
viz.cursor(viz.OFF)
viz.mouse(viz.OFF)
Old 08-17-2007, 04:49 PM
I tried your script but there were some errors with it. I fixed the errors and it works for me now. Can you try the following code:
MOVE_SPEED = 5
TURN_SPEED = 60
car = viz.add('mini.osgx')
def mytimer(num):
    updatecar()
def updatecar():
#def updatecar():
def mousemove(e):
    euler[1] = viz.clamp(euler[1],-90.0,90.0)
        updatecar()
viz.cursor(viz.OFF)
viz.mouse(viz.OFF)
Old 08-17-2007, 05:20 PM
HI farshizzo,
Thanks for your help. I tried your script using the files I modeled in 3ds Max instead of the ones with the tutorials and the problem remained. I'll double check my models and I'll let you know.
Vinicius
Old 08-20-2007, 09:53 AM
Even after double checking the files and the script it is not working. So, I was wondering if when I am exporting as .osg files I am not clicking one of the options or I am not doing it right. This has happened a couple of times already and I tried everything thinking the problem was in the script but my script is exactly like the one I got from you. So, I am guessing the problem is in the modeling. Could you help me?
Vinicius
Old 08-20-2007, 06:51 PM
I don't really understand what the problem is. You will need to post your model so I can test it out myself. If you prefer, you can email the model to lashkari@worldviz.com
