Old 05-31-2007, 07:40 AM
djdesmangles djdesmangles is offline
Exclamation Some problems...
Hello Wizards,
I've some codes that doesn't work... If I want a delay of 2 seconds before playing a sound:
# my variables
# wait for 2 seconds before playing track
def onTimer(num):
Track1.play()
viz.callback(viz.TIMER_EVENT, onTimer)
viz.starttimer(0, 2)
- If I want to listening to my joystick event:
# add a joystick and listen
joy = vizjoy.add()
def joystickListener(num):
y = joy.getPosition[1]
x = joy.getPosition[0]
if math.fabs(y) > 0.2:
viz.move(0,0,-y*0.1)
if math.fabs(x) > 0.2:
viz.move(x*0.1,0,0)
viz.callback(viz.TIMER_EVENT, joystickListener)
viz.starttimer(1, 0.001, viz.FOREVER)
The problem is that only the joystick fonction will work. The sound will never be played. If I change the first fonction to something that requires an infinite loop, the two callbacks will work !!!
I don't undestand why I can't have a delay while starting my joystick...
viz.FOREVER,
D.
Old 05-31-2007, 11:08 AM
You can only register one global callback function per event. If you want multiple callback functions for an event you need to use event classes. In this example you can also use a different timer ID for each case:
def onTimer(num):
    if num == 1:
        #Perform joystick listener code
    elif num == 0:
        Track1.play()
viz.starttimer(1, 0, viz.FOREVER)
Alternatively, you could use the vizact library:
def joystickListener():
    #joystick listener code
vizact.ontimer(0,joystickListener) #Call function every frame
vizact.ontimer2(2,0,Track1.play) #Play track in 2 seconds
Old 05-31-2007, 11:27 AM
Thumbs up Oki...
OOoooooww... I'm going to try...
Thanks a lot...
viz.FOREVER
D.
