Thread Tools Rating: Thread Rating: 42 votes, 5.00 average. Display Modes
Old 05-31-2007, 11:24 AM
vnellyaba vnellyaba is offline
poor LED detection
I am working with two lights, and the systems is having trouble keeping the tracking stable. (The indicator on the PPT screen flickers often between green, yellow and red) Which settings could be causing this and is there an online manual I can read on calibration etc.? This happens even if there are no other light sources in the room, and no objects blocking the cameras. Thanks!!
Old 06-05-2007, 06:13 PM
mspusch mspusch is offline
hi, which version of the PPT are you using? have you done the 1-point test as described in the manual?
also, which volume are you tracking in, and which distance do your LEDs have? are you using bright markers (marked with a red dot on the black battery case) or normal markers?
could you please send an email message with above details (as far as you have the info) to support@worldviz.com?
then we'll try help you fix the described problems, so you get a solid tracking performance
