Old 01-29-2004, 08:52 AM
keastman keastman is offline
Curtain problems
I would like to temporarily make the screen blank. Previously, I used the "curtain" function with vizard 1.08, but know that doesn't seem to work. The new "visible" function in visard 2.0 doesn't seem to work either. When I put it in the command line. I get:
File "<string>", line 2, in ?
File "test3.py", line 7, in ?
viz.visible(viz.ON)
AttributeError: 'module' object has no attribute 'visible'
However, it does exist in the help and in the viz.py file.
Kyler Eastman
Old 01-29-2004, 10:12 AM
Hi Kyler,
I suspect you have an older version of Vizard, the latest version is 2.14 and the viz.visible() command works properly. Just download the latest installer from the website and the command should work fine.
