Old 04-25-2014, 07:53 AM
Help with VizExtension.command?
I'm working to port a new version of our volume rendered over to C++ as a Vizard extension, but I'm running into some issues using the VizExtension.command method.
I followed your documentation, and I can construct a simple cube when I call my extensions .addNode() method.
However, when I try to use the .command method Vizard crashes on me every time.
Specifically, I'm just trying to send back bogus data from the C++ extension to Python using the data.set() method.
MyExtension Header
#pragma once
#include <viz\Extension>
#include <viz\python>
#include "MyNode.h"
class MyExtension : public viz::Extension
public:
	MyExtension(void);
	virtual const char* getName() const;
	virtual viz::Referenced* createNode(viz::Data &data);
	virtual void command( viz::Data& data);
protected:
	virtual ~MyExtension(void);
protected:
	osg::ref_ptr<viz::ExtensionOSGNode> node_;
MyExtension .ccp
#include "MyExtension.h"
MyExtension::MyExtension(void)
MyExtension::~MyExtension(void)
const char* MyExtension::getName() const
	return "My Extension";
viz::Referenced* MyExtension::createNode(viz::Data &data)
	node_ = new DummyNode;
	return node_.get();
void MyExtension::command( viz::Data& data )
	int command = data.getInt( "command" );
	switch(command)
		case 1:	//Passing in the camera's normal
			float tempX = data.getFloat("x");
			data.set(  PYTHON_RETURN_OBJECT, PYTHON_STRING("This is a test.") );
			break;
extern "C" __declspec(dllexport) viz::Extension* CreateVizardExtension(viz::Data &data)
	return new MyExtension();
