Old 02-01-2005, 04:20 PM
Can you try the following script and tell me what it prints out:
ppt = viz.add('vizppt.dls')
ppt.command(6,'',1,1,1)
ppt.reset()
viz.tracker()
viz.eyeheight(1.8)
def ontimer(num):
	print viz.get(viz.HEAD_POS)[1]
viz.callback(viz.TIMER_EVENT,ontimer)
viz.starttimer(0,0.1,viz.FOREVER)
It should load the ppt tracker, set the eyeheight to 1.8, and continuously print out the latest height of the viewpoint.
The average command will tell the ppt to average the position over the last N number of samples.
The reset mask controls which axes are affected by the reset command. By default all axes should be affected by the reset, but there was a bug in the ppt plugin which caused the y axis to not be affected.
