Old 11-29-2012, 02:27 AM
fordprefect fordprefect is offline
Exception in module vizjoy
Dear all,
while modifying our scripts I ran into an exception from the vizjoy module. While it is not much of a problem because the exception is thrown when closing the simulation, I'd like to get rid of it because it could obscure a true error. The programming goes like this:
script.py
import A
A.go()
module A.py
import B
import vizjoy
status = True
def go():
  B.start()
  status = ...
module B.py
import A
def start():
  """does some inits and install callbacks"""
def react():
  if A.status:
I found no way around this circular import of modules because I need access to the current value of A.status in Module B. I tried a getter-Method in A but this also throw me this exception:
Exception TypeError: "'NoneType' object is not callable" in <bound method _JoystickCleanup_.__del__ of <vizjoy._JoystickCleanup_ instance at 0x04787418>> ignored
Appreciate any hints, ideas and even solutions...
BR Walter
21 is only half the truth.
