I am trying to do a bit of vertex (and hopefully geometry) shading with the vertices of a node. Specifying a shader program with no fragment shader, or specifying the below fragment shader however both lead to color of the node being discarded.
obj = vizshape.addSphere()
shader = viz.addShader(vert=getVertexCode(),frag=None)
obj.apply(shader)
fragment shader instead of None above:
void main()
gl_FragColor = gl_Color;
Could you let me know what the passthrough vertex shader should look like in this case?
