Old 04-11-2016, 11:32 AM
Vaquero Vaquero is offline
Unhappy Augmented Reality: virtual world not overlapping real world correctly
I'm having the problem, that the virtual world and its objects don't overlap with the real world. When moving the head, the virtual environment moves with it to some degree. Why is that? There's a video link below.
I shortly described the issues I'm having with AR and the tracking in another thread, but decided it may deserve its own. I searched the forum for drift and how it could be related to the IntertiaCube, so I tested the head tracking with a rigid body composed only out of optical markers. There was quite a lot of jitter, but surpsingly the tilting world happened, too! So the inertia sensor can't be the sole cause.
Here's the recording: https://youtu.be/aU3ea96-3I0
It was really difficult holding the webcam inside the see-through-HMD, so I apologize for the bad quality.
Another issue is the scaling. When applying no scaling, it seems the ground is 0.8 lower than it should be, visually. That's the distance I have to lift the real object in order for the virtual one to be at my foot. It's hard to see in the video and much more prominent when really looking through the HMD with both eyes. When applying a scale of 0.5, visually it looks much more stable, and the virtual object approximately overlaps with the real one, but the coordinates get halved, which I don't want. Also moving up and down seems to move the floor in opposite direction.
In both cases, the closer I get to the ground, the more it seems to kind of match.
Here's my code:
import vizconnect
import vizshape
import nvis
nvis.nvisorST()
# This is the variable I try to find the correct values for
scaleFactor = [0.5, 0.5,0.5] # seems more correct in the view, but coordinates are halved
#scaleFactor = [1, 1, 1]
# Use VRPN to connect to phasespace.
vrpn = viz.add('vrpn7.dle')
VRPN_SOURCE = 'Tracker0@localhost'
headSensor = 0
rigidSensor = 5
headPosTracker = vrpn.addTracker(VRPN_SOURCE,headSensor)
headPosTracker.swapPos([1,2,-3])
headPosTracker.waitForConnection(timeout=0.5)
# add iSense tracker (inertia tracker on HMD)
isense = viz.add('intersense.dle')
headOriTracker = isense.addTracker()
vizact.onkeydown('r',headOriTracker.reset)
# Merge head trackers to a 6DOF tracker and link to main view
headTracker = viz.mergeLinkable(headPosTracker, headOriTracker)
viewLink = viz.link(headTracker,viz.MainView)
# convert input to vizard's coordinate system
viewLink.swapPos([-1, 2, -3])
# the tracked LED is not where the eyes are, so adjust it?
#viewLink.preTrans([0,-0.08,-0.05]) # preTrans?
#viewLink.postTrans([0,-0.08,-0.05]) # or postTrans?
# Now this is where the scale comes into play
viewLink.postScale(scaleFactor) # scale the tracker coordinates before applying them to the camera (viewpoint)
# Add text for displaying head tracker coordinates
headText = viz.addText('head:',parent=viz.SCREEN)
headText.fontSize(60)
headText.color(viz.RED)
headText.setPosition(0,0.95)
rigidTracker = vrpn.addTracker(VRPN_SOURCE,rigidSensor)
# Add a axis model to the tracker for visualization
rigidAxis = vizshape.addAxes(length=0.1)
rigidAxisLink = viz.link(rigidTracker,rigidAxis)
rigidAxisLink.swapPos([-1, 2, 3])
rigidAxisLink.swapQuat([-1,2,3,-4])
rigidAxisLink.postScale(scaleFactor) # scale the tracker coordinates before applying them to the rigid body link
# display the coordinates at the tracker
rigidText = viz.addText3D('tracker',pos=[0.02,0.02,0],scale=[0.05,0.05,0.05],parent=rigidAxis)
rigidText.color(viz.YELLOW)
# updates the coordinates in the text elements
def updateCoordinateDisplays():
	#first update the coordiantes for the headTracker
	headX = '%.3f' % viewLink.getPosition()[0]
	headY = '%.3f' % viewLink.getPosition()[1]
	headZ = '%.3f' % viewLink.getPosition()[2]
	sep = ","
	seq = (headX, headY, headZ)
	coords = sep.join(seq)
	headText.message('head:' + coords)
	#update 3D text for rigid tracker
	rigidX = '%.3f' % rigidAxisLink.getPosition()[0]
	rigidY = '%.3f' % rigidAxisLink.getPosition()[1]
	rigidZ = '%.3f' % rigidAxisLink.getPosition()[2]
	seq = (rigidX, rigidY, rigidZ)
	rigidText.message(coords)
viz.mouse.setVisible(True)
# Add a grid for reference
vizshape.addGrid(size=(5,4), step=0.1, boldStep=0.5, axis=vizshape.AXIS_Y, lighting=False)
# show XYZ axes geometry
originAxes = vizshape.addAxes(length=0.5)
# Update coordinate display every frame
vizact.onupdate(0,updateCoordinateDisplays)
# Just to make sure vertical sync is ON
viz.vsync(1)
# Helps reduce latency
viz.setOption('viz.glFinish',1)
# 4x antialiasing
viz.setMultiSample(8)
# Display world in HMD
viz.window.setFullscreenMonitor([4,3])
viz.go(viz.FULLSCREEN|viz.STEREO)
Since the marker position is probably not the position I want the view to originate from, should I use preTrans or postTrans on the link? I don't quite understand the difference. And where should the view actually originate from? Eye position? Could this be a cause for the drift?
