Old 09-06-2012, 12:36 PM
nihohit nihohit is offline
Exposing an intersense cube via VRPN
I'm trying to set up PPT's MoCap plugin, but I'm a bit confused.
The way we are setup is that we have two machines, call them A and B - one with the Intersense cube attached to it (well, the cube is on a helmet attached to the machine) and the other running PPT Studio. The two machines are connected via ethernet.
As far as I understand, I need to have a VRPN server running on machine A so that the VRPN Input plugin on machine B can read from it. Is this correct?
If so, how do I expose this functionality? Machine B does have Vizard, if I'm missing something there. Otherwise, I have tried to download the actual VRPN server from here: http://www.cs.unc.edu/Research/vrpn/ but I've found a dearth of data on how to configure that server so as to expose the Intersense cube. Does anybody here know?
Thank you.
