Old 03-12-2014, 07:26 AM
ptjt255 ptjt255 is offline
Thanks Jeff, I think I knew that somewhere in the depths if my memory from a similar issue a few years ago.
Unfortunately, in this instance adding the missing files hasn't worked.
I have tried just running the code that seems to be causing the problems:
C:\Program Files\WorldViz\Vizard30\python\numpy\_int_.py
and I'm getting the following error:
File "<string>", line 1, in ?
File "C:\Program Files\WorldViz\Vizard30/python\viz.py", line 14, in ?
import vizmat
File "C:\Program Files\WorldViz\Vizard30/python\vizmat.py", line 3, in ?
from random import random
File "random\__init__.py", line 3, in ?
from mtrand import *
File "numpy.pxi", line 74, in mtrand
File "C:\Program Files\WorldViz\Vizard30\python\numpy\__init__.py", line 37, in ?
import testing
File "C:\Program Files\WorldViz\Vizard30\python\numpy\testing\__ini t__.py", line 3, in ?
from numpytest import *
File "C:\Program Files\WorldViz\Vizard30\python\numpy\testing\numpy test.py", line 19, in ?
from numpy.distutils.exec_command import splitcmdline
File "C:\Program Files\WorldViz\Vizard30\python\numpy\distutils\__i nit__.py", line 6, in ?
import ccompiler
File "C:\Program Files\WorldViz\Vizard30\python\numpy\distutils\cco mpiler.py", line 6, in ?
from distutils.ccompiler import *
File "distutils\__init__.py", line 6, in ?
import ccompiler
File "distutils\ccompiler.py", line 7, in ?
from distutils import ccompiler
ImportError: cannot import name ccompiler
** ERROR: Failed to initialize python
