Old 09-06-2012, 10:05 AM
goro goro is offline
Solved first issue of my own
I have solved first issue of my own. That error was because Vizard free version changes its resolution after 20 Seconds. I have made the code dynamic.
import vizhtml
import vizcapture
viz.setMultiSample(4)
viz.fov(60)
import vizinfo
info = vizinfo.add('This script demonstrates how to add multiple windows.\nThe upper right window is a rear view of the scene\nThe upper left window is a birds eye view')
info.translate([0.95,0.05])
info.alignment(vizinfo.LOWER_RIGHT)
#resolution of Web Page Image
w = 160
h = 120
#Add environment
viz.addChild('maze.osgb')
# Create a new window in the upper left corner
UpperLeftWindow = viz.addWindow(pos=(0,1.0),size=(0.2,0.2))
UpperLeftWindow.visible(0,viz.SCREEN)
#Create a new window in the upper right corner
UpperRightWindow = viz.addWindow(pos=(0.8,1.0),size=(0.2,0.2))
UpperRightWindow.visible(0,viz.SCREEN)
# Create a new viewpoint
BirdView = viz.addView()
#Attach the bird's eye view to the upper left window
UpperLeftWindow.setView(BirdView)
#Move the view above the center of the room
BirdView.setPosition([0,25,0])
#Rotate the view so that it looks down
BirdView.setEuler([0,90,0])
#Create another viewpoint
RearView = viz.addView()
#Attach the rear view to the upper right window
UpperRightWindow.setView(RearView)
#Increase the field-of-view for both windows
UpperLeftWindow.fov(60)
UpperRightWindow.fov(60)
#Add an arrow marker to bird's eye view window to represent our current position/orientation
arrow = viz.addTexQuad(parent=viz.ORTHO,scene=UpperLeftWindow,size=20)
arrow.texture(viz.add('arrow.tif'))
# Web Socket & HTML 5 Code
code = """
<html>
<head>
    <title>vizhtml WebSocket Example</title>
    <script type="text/javascript" src="vizhtml.js"></script>
</head>
<body>
<canvas id="VizardScreen" width="180" height="140" style="border:1px solid #d3d3d3;">
Your browser does not support the HTML5 canvas tag.</canvas>
<script language="javascript">
var socket = new VizardWebSocket();
var c=document.getElementById("VizardScreen");
var ctx=c.getContext("2d");
var imgData=ctx.createImageData(160,120);
socket.onevent('open', function(e){
    document.getElementById('status').innerHTML = 'connected';
    document.getElementById('my_button').disabled = false;
socket.onevent('close', function(e){
    document.getElementById('status').innerHTML = 'waiting for connection';
    document.getElementById('my_button').disabled = true;
    socket.reconnect();
socket.onevent('set_time', function(e){
    document.getElementById('script_time').innerHTML = e.data.time;
socket.onevent('set_data', function(e){
var j = 0;
for (var i=0;i<imgData.data.length;i+=4)
  imgData.data[i+0]=e.data.iData[j+2];
  imgData.data[i+1]=e.data.iData[j+1];
  imgData.data[i+2]=e.data.iData[j];
  imgData.data[i+3]=255;
  j+=3;
ctx.putImageData(imgData,10,10);
var click_count = 0;
function onButtonClick()
    click_count += 1;
    socket.send( 'button_click' , VizardData({'count':click_count}) );
</script>
<div>Status:</div><div id='status'>waiting for connection</div></br>
<div>Time:</div><div id='script_time'></div></br>
<div><input id='my_button' type=button value="Send Message" onclick="onButtonClick();"></div></br>
</body>
</html>
# http://localhost:8080/vizhtml/websocket
vizhtml.registerCode('websocket',code)
def ClientConnect(e):
    print 'Client connected at',e.client.address
vizhtml.onConnect(ClientConnect)
def ClientDisconnect(e):
    print 'Client disconnected at',e.client.address
vizhtml.onDisconnect(ClientDisconnect)
def SendTime():
    d = viz.Data(time='%.1f'%(viz.tick()))
    vizhtml.sendAll('set_time',d)
vizact.ontimer(0.1,SendTime)
def OnButtonClick(e):
    print 'BUTTON CLICK',e.data.count,'from',e.client.address
vizhtml.onMessage('button_click',OnButtonClick)
def SendImageData():
    global w
    global h
    width,height,data = vizcapture.screenBuffer(flip = True)
    lendata = len(data)
    if data:
        print width,height,lendata
        iData = []
        for j in range (h):
            for i in range(w):
                iData.append(ord(data[800*3*int((height/h)*(j-1))+3*int((width/w)*(i-1))]))
                iData.append(ord(data[800*3*int((height/h)*(j-1))+3*int((width/w)*(i-1))+1]))
                iData.append(ord(data[800*3*int((height/h)*(j-1))+3*int((width/w)*(i-1))+2]))
        d = viz.Data(iData = (iData))
        print len(iData)
        vizhtml.sendAll('set_data',d)
        print len(iData)
vizact.ontimer(0.1,SendImageData)
def UpdateViews():
    #Get the current head orientation and position
    yaw,pitch,roll = viz.MainView.getEuler()
    #Move the rear view to the current position
    RearView.setPosition(pos)
    #Rotate the rear view so that it faces behind us
    RearView.setEuler([yaw+180,0,0])
    #Move arrow to our current location
    x,y,z = UpperLeftWindow.worldToScreen(pos,mode=viz.WINDOW_PIXELS)
    arrow.setPosition([x,y,0])
    arrow.setEuler([0,0,-yaw])
vizact.ontimer(0,UpdateViews)
# Turn on collision detection so we can't go through walls
viz.collision(viz.ON)
