Old 03-26-2003, 10:04 AM
hotspur1 hotspur1 is offline
Thanks. That works like a charm! I think you put the quotes around the wrong part of the command in your example....
As a follow-up, is there a clean way to exit Vizard as well? I can exit the graphics portion with viz.quit() but is there a way to also exit Vizard.exe without using the menu option?
