Hi Roy,
There was just a bug in your code. You were setting "avatarAnim" to visible off and on states in your experiment function instead of using "trial" which would iterate between your shuffled states.
import random
import viztask
avatar_files = ['vcc_male.cfg', 'vcc_female.cfg']#2avatars
animation = range(0,16) #default 15 animations
piazza = viz.addChild('piazza.osgb')
#make 30 stimuli list (2 avatars x 15 animations), and shuffle the order
stimulus = []
for i in avatar_files:
for j in animation:
avatarAnim = viz.addAvatar(i, pos=(0,0,0), euler=(180,0,0))
avatarAnim.state(j)
avatarAnim.visible(viz.OFF)
stimulus.append(avatarAnim)
print(stimulus)
random.shuffle(stimulus)
print(stimulus)
def experiment():
yield viztask.waitKeyDown(viz.KEY_RETURN)
for trial in stimulus:
yield viztask.waitTime(1)
trial.visible(viz.ON)
trial.visible(viz.OFF)
viztask.schedule(experiment())
Check this and let us know if this was your intended experiment. Thanks
