Old 04-29-2010, 11:42 AM
masaki masaki is offline
hi can you try this modified script and see what you get? The modifications are:
- stimulus changing color is not triggered by a random time - you trigger it by hitting the space bar. So essentially, it measures the time interval between two key presses instead of measuring your reaction time.
- there is a timer function that prints the elapsed time between stimulus change and keypress.
- i've added a second viz.Data object called dd and used that one for storing the time data from the second waitkeydown function.
I tested the code with an external stopwatch and seems accurate.
import vizinfo
info = vizinfo.add( 'This script uses precisely timed input recording to measure your reaction time.\nPress any key when the color changes to green.\nCan you get under .2 seconds?' )
#Add quad to screen
quad = viz.addTexQuad( viz.SCREEN , pos=(0.5,0.5,0) , scale=(4,4,4) )
#Display time on screen
timeDisplay = viz.addText( 'Time:', viz.SCREEN , pos=(0.1,0.2,0) )
import viztask
import time
starttime = time.time()
stopWatch = False
def TestReactionTime():
    global starttime, stopWatch
    #Data for getting values from wait conditions
    d = viz.Data()
#    dd = viz.Data()
    while True:
        #Set quad to red color
        quad.color(viz.RED)
        #Wait random amount of time
        stopWatch = True
        #Set quad color to green
        quad.color(viz.GREEN)
        #Wait for next frame to be drawn to screen
        yield viztask.waitDraw(d)
        #Save display time
        displayTime = d.time
        #Wait for keyboard reaction
        yield viztask.waitKeyDown(None,d)
        #Calculate reaction time
        reactionTime = d.time - displayTime
        #Print and display time
        print 'Reaction time:',reactionTime
        timeDisplay.message( 'Time: %.5f' % (reactionTime) )
        stopWatch = False
viztask.schedule( TestReactionTime() )
def showTime():
	if stopWatch:
		print time.time() - starttime
vizact.onupdate(-100, showTime)
Best,
Masaki
