Old 12-01-2004, 01:35 PM
I wrote the following sample script that should fix your problems. I use the viewpoints built-in animation engines to translate and rotate. When they are finished I translate/rotate them to the final value just to be sure they are exact. Also, when I calculate where to move/turn, I round the values to integers. Also, I check if the viewpoint is currently being animated when a key is pressed.
#Add a ground
viz.add('tut_ground.wrl')
#Get main viewpoint object
#Create a variable that will tell whether viewpoing is currently moving/turning
view.animating = 0
#Variable that holds current destination value
final = [0,0,0,0]
def onkeydown(key):
	if key == viz.KEY_UP:
		#Make sure view is not animating
		if not view.animating:
			pos = view.get(viz.HEAD_POS)
			trans = view.get(viz.BODY_LOOK)
			#Round values to nearest integer
			final[0] = int(round(pos[0] + trans[0]))
			final[1] = int(round(pos[1] + trans[1]))
			final[2] = int(round(pos[2] + trans[2]))
			#Start animating viewpoint
			view.goto(final,1,viz.TIME)
			view.animating = 1
	elif key == '6':
			#Compute rotation of turning body 90 degrees to right
			xform = viz.Transform(view.get(viz.BODY_MAT))
			xform.postRot(0,1,0,90)
			rot = xform.getRot()
			final[0] = int(round(rot[0]))
			final[1] = int(round(rot[1]))
			final[2] = int(round(rot[2]))
			final[3] = int(round(rot[3]))
			view.spinmask(viz.BODY_ORI) #Spin the body orientation
			view.spinto(final,45) #Spin with speed of 45 deg/sec
			view.animating = 1
def onstop(object, type):
	if type == viz.MOVE:
		#Viewpoint is done moving, translate it to the final value just to be sure
		view.translate(final)
		view.animating = 0
	elif type == viz.SPIN:
		#Viewpoint is done spinning, rotate it to the final value just to be sure
		view.rotate(final,viz.BODY_ORI)
		view.animating = 0
view.callback(viz.STOP_EVENT,onstop)
