Old 11-24-2004, 05:44 PM
Does the lag occur every time an avatar performs an action? Does the lag last as long as the action? Can you try running the following script and seeing if it reproduces the lag. The script loads 7 avatars and pressing the spacebar will execute an animation on one of them. I've tried it here and I don't notice a lag.
NUM_AGENTS = 7
for x in range(NUM_AGENTS):
	agent = viz.add('male.cfg')
	agent.translate((NUM_AGENTS/-2.0) + x*1.5,0,15)
	agent.rotate(180,0,0)
	agent.state(1)
def onkeydown(key):
	if key == ' ':
		agent.execute(5)
viz.callback(viz.KEYDOWN_EVENT,onkeydown)
