Thread: vizrecorder
Old 11-09-2004, 05:43 PM
It should also print out another line that says what caused the error. Either way, can you check that DirectX 8.0 or above is installed on your computer.
To check, click the Windows Start menu, then Run. Type in "dxdiag" then press enter. A dialog should appear. On the first page of the dialog there will be a field that says "DirectX version:"
