Old 02-10-2010, 03:03 PM
vissimutah vissimutah is offline
Mirrors and Nvis Nvisor
using the Knowledge base mirror code in conjunction with the Knowledge base nvisor code seems to blank the right eye of the nvisor.
vprn = viz.add('vrpn7.dle')
headTracker = vprn.addTracker('PPT0@172.19.1.23')
headlink = viz.link(headTracker,viz.MainView)
viz.eyeheight(0)
viz.displaymode(2560, 1024)
viz.go(viz.STEREO | viz.FULLSCREEN)
REFLECT_MASK = viz.LAST_MASK << 1
def addMirror(mirror,mat=None):
	#If mirror matrix is not specifed, get matrix of mirror object
	if mat is None:
		mat = mirror.getMatrix()
	#Position of mirror
	pos = viz.Vector(mat.getPosition())
	#Direction mirror is pointing
	dir = viz.Vector(mat.getForward())
	dir.normalize()
	#Quaternion rotation of mirror
	quat = mat.getQuat()
	for eye in (viz.RENDER_LEFT,viz.RENDER_RIGHT):
		#Create render texture
		tex = viz.addRenderTexture()
		#Create render node for rendering reflection
		lens = viz.addRenderNode(size=[1024,1024])
		lens.setCullMask(REFLECT_MASK)
		lens.attachTexture(tex)
		lens.setInheritView(True,viz.POST_MULT)
		lens.disable(viz.CULL_FACE,op=viz.OP_OVERRIDE)
		lens.disable(eye)
		#Setup reflection matrix
		rot = viz.Matrix.quat(quat)
		invRot = rot.inverse()
		lens.setMatrix(viz.Matrix.translate(-pos)*invRot*viz.Matrix.scale(1,1,-1)*rot*viz.Matrix.translate(pos))
		#Setup reflection clip plane
		s = -viz.sign(viz.Vector(dir) * viz.Vector(pos))
		plane = vizmat.Plane(pos=pos,normal=dir)
		dist = plane.distance([0,0,0])
		lens.clipPlane([-dir[0],-dir[1],-dir[2],s*dist+0.1])
		#Project reflection texture onto mirror
		mirror.texture(tex)
		mirror.texGen(viz.TEXGEN_PROJECT_EYE)
import nvis
nvis.nvisorSX()
#Add gallery environment
import vizlens
pincushion = vizlens.PincushionDistortion()
#Use existing painting as mirror and specify the matrix
mirror = gallery.getChild('art04-FACES')
m = viz.Matrix()
m.setPosition(mirror.getPosition(viz.ABS_GLOBAL))
m.setEuler(180,0,0)
#Apply mirror settings to mirror object
addMirror(mirror,m)
#Increase ambient lighting
viz.MainView.getHeadLight().ambient(1,1,1)
#Create a self avatar
avatar = viz.add('vcc_female.cfg')
#Link avatar body to viewpoint
avatarLink = viz.link(viz.MainView,avatar)
avatarLink.setPos([None,0,None]) #Keep avatar on floor
avatarLink.setEuler([None,0,0]) #Only update avatar yaw
avatar.setMask(viz.LEFT_MASK|viz.RIGHT_MASK,mode=viz.MASK_REMOVE) #Only draw avatar in mirror
#Link avatar head to viewpoint
head = avatar.getBone('Bip01 Head')
head.lock()
viz.link(viz.MainView,head,mask=viz.LINK_ORI)
Each section of provided code utilizes different arguments to viz.go(), but I haven't managed to correct the problem by using either or both of them.
I've also tried using the monocular mirror code but that creates more complicated problems.
