Old 01-05-2010, 03:29 PM
The two cameras that are showing up as white need to be activated. Right click and then select Active to use these cameras.
It sounds like you might have some extraneous light in your workspace causing the cameras to see something other than the calibration rig's light. If you turn off the rig and any markers and darken the room do you still see a cross-hair? If so, you need to block out the light causing this or crop out the region of the camera where this light is.
The other errors are a result of having post-process plug-ins loaded without the proper markers or Intersense connected. For now, remove the post-process plugins and get tracking to work properly first.
What version of PPT Studio do you have installed? You can find that under Help --> About PPT. That may explain the "PPT failed to keep up" message.
