Old 12-09-2009, 12:56 PM
To return the IDE to original settings you will need to go into the registry. From the start menu select Run and then type in regedit. Go to HKEY_CURRENT_USER --> Software --> WorldViz. Under WordViz delete Vizard30 and when asked whether you want to delete this key and all subkeys say yes. Then when you restart Vizard the windows should be in their original positions.
