10-28-2009, 05:03 PM
Veleno, Farshizo,
Have you guys seen this kind of error before. Seems like a version issue between Max and the OSG exporter.
Claudio,
Do you have any other OSG applications on your computer? Perhaps some other OSG dll file is on your PATH variable that the exporter is trying to use?
Hi Paul,
I reinstalled Max2010 and OSGExport but nothing changed, the error still occuring when a Export to OSG. I've posted a snapshot of error message at the "plug-in development" Forum. Is there any other thing that I could try?
Thanks for your time, regards,
Claudio
Originally Posted by Gladsomebeast
Helllo Claudio,
I would try to re-install Max and the OSG exporter from the Worldviz/Vizard download page. Mabey first start by just re-installing the OSG exporter cuze that quick.
If that does not work, go ahead and post a new thread on the forum. Include a screenshot of the error (print-screen key). The developer of the OSG exporter reads the forum.
Sorry for the lame answer. Crashing on a simple box is kind of weird.
Best,
Paul
Hi Paul,
My name is Claudio and I'm have a problem to export .OSG file in 3DS MAx 2010. It seems to be installed (OSG Export) correctly in Max 2010, but the problem is that in the middle of the exporting process an error occurs and close the Max application and don't export the model. I tried to export an model and also a simple Box, even the box returned the error, so I guess the problem is not in my model...
Can you help me?
Regards,
Claudio
Paul Elliott
WorldViz LLC
