Old 10-25-2009, 10:02 AM
Mxd70 Mxd70 is offline
3d Utility Visor
Mohammed,
I followed the steps and downloaded the Labtool utlity. I have a Quadro FX 1600. I can get stero to flash on the HMD but then it disappears. The light turns from yellow to green for about half a second and then I lose stereo. Any suggestions?
Thanks.
Originally Posted by m7ossny View Post
We had the same problem with 4600 Quadro, and 8600 GT. Same symptoms, the stereo is not working, messed up drivers, projecting the shuttering exactly to both eyes, ... .
If you are as desperate as I am, there is a solution. Forget about the stereo driver. If you have it just disable stereo at all. Download a 3dvisor's utility called labtool (http://www.3dvisor.com/support.php). It forces the 3d mode to the emagin box. We tried it with 162.15/18, and the monitor was daisychained to the emagin box and it worked.
Regards. Mohammed Hossny.
